electric supercharger
Old Apr 7, 2003 | 09:28 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Your kidding right? There is no way in hell that an electric motor can sustain the CFM levels needed to create a forced induction application.
Stop shopping on ebay for parts
Old Apr 7, 2003 | 09:42 PM
mmboost's Avatar
Hehehe, did you see the picture going around that had a Mustang with an electric Toro leaf blower motor on the intake?
jason
Old Apr 7, 2003 | 10:12 PM
Re: no
Originally posted by Johnny Rocks
no why?
because it's frikkin' hilarious!
Old Apr 8, 2003 | 08:04 AM
Northrn Snowman's Avatar
Car Info: WRX SW 02
Actually there are electric assist turbochargers under development:
There is an electric motor/generator on the turbo shaft of the turbocharger that is used to spin it at low engine rpm's. It is supposed to eliminate turbo lag. Pb is it requires a lot of juice. This is solved with bigger batteries and a motor/generator that control maximum boost by braking the turbo and generating electricity.
Still experimental, though.
If you want I can try to find some articles on it.
Old Apr 8, 2003 | 06:28 PM
Kay95's Avatar
electric supercharger/turbocharger could be done with a large enough blower of air but the problem is power and room requirements.
Old Apr 9, 2003 | 02:57 PM
mmboost's Avatar
It should be called a "turbocharger assist" not an "assist turbocharger" because it "charges" nothing. This doesn't qualify at all as an electric turbocharger. It does not compress the intake. It keeps a turbo spooled to a certain RPM nothing more.
If Johnny Rocks had mentioned one of these, we probably woulda been like "ooooh neat idea"
jason
Old Apr 9, 2003 | 02:58 PM
mmboost's Avatar
A battery that pushes like 2000 watts
jason
Old Apr 9, 2003 | 05:34 PM
enigma's Avatar
Why an Electric Supercharger Will NOT work
You could create an electric supercharger.
but why?
An electric supercharger claims advantage over a traditional suypercharger due to the fact that it does not run on a belt drawing power from your car. Instead it runs on electricity.
One Question:From where does it get its electricity?
Answer:Same place everything else does...the alternator...whichs runs off a belt and robs power.
So, by the time you install an alternator large enough to push a SC, you really haven't accomplished anything. Actually, you have lost since their is never 100% efficiency in energy transfer.
Sound reasonable?
Old Apr 22, 2003 | 06:56 AM
Car Info: WRX SW 02
Reply to Dr Moreau
That's exactly how it is supposed to work.
I have read too that they might use the electric motor to control over boost by slowing the turbo down by generating electricity:
To read more see the section about electric drive turbo's in:
http://www.autofieldguide.com/articles/050103.html
Is Less More?
By Christopher A. Sawyer, Executive Editor
By the way, what kind of animal are you?
rugmonkey
May 22, 2008 05:24 PM
hutman4
Mar 23, 2007 08:21 AM
knight1833
Jul 5, 2005 06:09 PM
I3eXa
Wanted
Apr 23, 2003 07:43 PM
