Do I need tuning for uppipe/downpipe? (was: Wondering about this statement)
Car Info: '03 PSM Wingless WRX
Wondering about this statement..
Originally Posted by jireh4you
up and dp. it pulls harder. lol but u need to get ecutek.. or else it'll over boost and blow up ur engine or turbo... (I NEED an ECUtek BADLy before its too late... where can i get a cheap one?)
How true is that statement up there??? can't you just run up/dp and then add a Cobb then you dont need the tune right? or can you do without the cobb and the tune?
From: Stop drag racing a rally car, and you'll be OK
Car Info: WRX STi
That would depend on how hard your gonna drive it. If you want to drive it hard you will need a tune or else you could suffer engine damage. A re-flash will also net you decent performance gains.
I ran up/dp with a stock CBE for a while without any problems. I then added a borla hush and went for a while longer still without a tune and still without any problems. Once I got a tune the car was a **** load faster
oh yeah, I did two rally-x's with the up/dp on and a track day at laguna seca after I got the CBE but still without the tune
Car Info: 2005 CGM WRX Wagon
Doesn't it depend on the year of your WRX? I thought that with the 05's at least (and possibly 04's as well) the ECU would freak out and it would be dangerous to run UP/DP without a tune. Perhaps I'm mistaken, and I don't know the details, but I know I heard that before...
Oh sounds great... Cuz I was thinking about doing the up/dp, but didn't really want to tune the car at this moment. ( cash issues) So yeah... Just got a little freaked out reading that post, eh... Thanks Guys!
02-03 ECUs will "work".
04+ ECUs running with up/dp and no tuning will blow **** up. Go ask ipozestu, it happened to him on his 04 and ended up getting a built motor.
and btw, i wouldnt run catless w/o tuning. it will cause your car to overboost (boost creep) and will probably have leaner afr's because your ecu is set for stock boost.
i'd go with the cobb ap first. you'll get some good gains and later down the road your up/dp mods will have some insurance for your motor.
