Do I need a fuel pump for stage 2 2013 wrx?
I was wondering if i would need to upgrade my fuel pump for my 2013 wrx. I read some forums and they said you don't. So i'm just making sure if it's really recommended.
are you just going to be running an OTS cobb stage 2 map? If so, you do not need a fuel pump. If you plan on getting tuned you probably will, but I would talk with your tuner first and see what their preference is.
Car Info: 03 WRX, 15 Sti, 14 Sti, 11 GMC 2500
I have tuned them both ways on the newer wrx's the upgrade pump does help with the fueling on the car and in turn will make more power.
Yes that is true but if you at least have a fuel pump that flows more than the stock pump your injector won't max out as soon. But you can still max them out with a upgraded pump too.
Car Info: his wife crazy
Thanks Snail!
drifter04
Nov 5, 2008 10:38 PM
dan2304k
Wanted
May 25, 2006 04:28 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
JohnB
Jun 30, 2003 12:14 PM
