COBB AP Problem!!
Old Jul 18, 2005 | 08:55 PM
Uniquedude's Avatar
COBB AP Problem!!
Hi. I'm driving an 05 WRX with Cobb Stage 2. Now, everything sounds fine and feels ok, but first, I can't reach the target boost. It's always on mid 14's and when I tried to swap in a new base map, it says Car's voltage is low check cable.
I'm wondering if anyone's got a same problem or is it just my car is bad.
Some advises please.
Old Jul 19, 2005 | 08:50 AM
BoostinEJ20's Avatar
any of the doors open when u get voltage low?
Old Jul 20, 2005 | 01:57 AM
Uniquedude's Avatar
Not at all. All doors were closed. And I even turned off every single switch that might affect it, but still. Should it be the battery? Is it possible anyway?
Old Jul 20, 2005 | 04:12 AM
808subaru's Avatar
Car Info: 09 xt
i had that prob. b4. i got a bad accessport and traded it in i also cannot hit target boost btw, and i have had mine for about 10 months now.
Old Jul 20, 2005 | 11:07 AM
Uniquedude's Avatar
So after you exchanged it, all problems seem to disappeared??
Old Jul 20, 2005 | 01:05 PM
Brood's Avatar
Uniquedude, the voltage error code can happen if the car has been sitting there for a while without being started, or if the battery is in need of replacement. Basically, the ECU in your car needs sufficient voltage throughout the entire flashing process or it's possible to damage the ECU. As far as not hitting target boost, have you tried the high waste gate (HWG) maps? If you have more questions, let me know or call our support line 801-713-0035. I hope this helps.
Scott
COBB Tuning
Old Jul 20, 2005 | 02:23 PM
ElectronBlur's Avatar
Car Info: 05' STi / 90' 240sx
I hope you get this worked out soon. Im planning on ordering mine soon so let us know what happens.
srbaugust
15
Jun 2, 2013 02:02 AM
roninrider_9
Apr 6, 2012 11:33 AM
sjice
Dec 31, 2005 01:15 AM
razorlab
May 10, 2004 10:13 AM
