Cobb AP .. which map fixes dp wastegate problem for STi?
Old Dec 30, 2005 | 10:06 PM
sjice's Avatar
Car Info: '13 BRZ - SWP
My STi has the usual boost problem after I installed my helix downpipe. When i hit a certain MPH or psi the engine freaks out and shuts down the acceleration. I am gettin a Accessport this Saturday, and I'm wondering what map I should use? I'm going to install a california map, but I was wondering which one to do..
Stage 2 LWG Cal Stage 2 mapping for California fuel with lower Wastegate Duty Cycle mapping to eliminate boost spiking experienced with some owners. 1.10
or
Stage 2 HWG Cal Stage 2 mapping for California fuel with with higher Wastegate Duty Cycle mapping for those unable to hit the boost targets. 1.10 [base map]
Old Dec 30, 2005 | 10:37 PM
mcowger's Avatar
Car Info: 2009 A3 2.0T quattro
Try the regular map to start with, and see if you are fine. If you overboost, switch to the LWG. If you dont hit targets, go for the HWG.
Old Dec 30, 2005 | 11:09 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
I personally like the ca. map
Old Dec 30, 2005 | 11:33 PM
Krinkov's Avatar
cant tune out a too-smal WG opening, soory
Old Dec 31, 2005 | 01:15 AM
SubyN00by's Avatar
turbo port time! call gruppe-s!
A170123W
Jul 6, 2007 07:30 AM
carletto
Jul 23, 2005 03:20 PM
willow
Mar 13, 2004 08:41 AM
Speed Element
Vendor Group Buys/Specials
Nov 10, 2003 09:58 AM
