Cobb AP: Bucking symptom of Detonation?
Old May 23, 2005 | 11:06 AM
Clint Torres's Avatar
Car Info: 2003 GGA
Hey All,
In need of a lil' info.
I'm running Cobb AP Stage 1 HWG on my 03 Wagon.
HWG increases the wastegate duty cycles in order to increase boost. I wasn't reaching the target 14.5 +/-.5PSI until I used this map.
The problem is that I'm experiencing bucking in 2nd gear at around 4000rpm. Its brief but alarming.
My question is: Is the bucking a symptom of something harmful like detonation?
TIA for any input :P
Old May 24, 2005 | 12:02 PM
Car Info: 2003 GGA
bumpity bump
Old May 31, 2005 | 11:57 AM
is it like a mis fire or a shut down of the engine?
Old May 31, 2005 | 11:58 AM
is the boost spiking? any noises going on at the same time?
Old May 31, 2005 | 12:30 PM
Egan's Avatar
Bucking could be the ECU not being able to handle the fuel load. My 02 wagon bucked like a bronco if I got on the boost during the drive from my house (where I put in VF30/pinks/fuel pump/rails) and my tuner's shop. Once the reflash was done, all was well again.
It's possible your map has some incorrect fueling right where you are getting the bucking.
Old Jun 6, 2005 | 04:34 PM
Car Info: 2003 GGA
Sorry for the late reply, I was on vacation last week.
I've been changing the maps to the stage1 CA 91oct and back to stage1 HWG and now the bucking has seemed to have vanished. Who knows? Maybe it has something to do with the ECU learning.
All I know is the stage1 HWG map is the only one that provides a palpable increase in performance. Guess my wastegate is a lil looser than others'.
Old Jun 8, 2005 | 03:25 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
It sounds like the ECU encountered knock in a certain spot and pulled timing. When you switched maps, you reset all ECU learning, so the problem went away. If the cause of the knock was some sort of glitch or a bad tank of gas, you should be ok, but if there is an issue that is persistantly causing knock in that region, the ECU will re-learn the behaviour.
Old Jun 8, 2005 | 03:42 PM
Car Info: 2003 GGA
That's why I switched to the stage 1 CA 91 octane map. But that map sucks for me, perfomance-wise.
What I need is for Cobb to put out a stg1 CA 91oct HWG map. They have one for the STI but not WRX.
Looks like I'll have to request one.
So my next question would be: How much harm am I doing to my engine if the ECU is detecting knock and pulling the timing?
hamez
Jun 28, 2004 05:26 PM
Trolleyop
Apr 21, 2004 08:59 AM
Trolleyop
Apr 20, 2004 07:49 AM
scootr
Nov 27, 2002 09:15 PM
Top
