Cobb Accesstuner.
Old Jan 19, 2005 | 12:57 AM
02scubyroo's Avatar
Car Info: 2002 WRX
Exclamation Cobb Accesstuner.
anyone know anything about it???
http://cobbtuning.com/wrx/under-dev.html#tuner
i mean that explains some of it but what else... anyone/???
Old Jan 19, 2005 | 08:51 AM
stimul8n's Avatar
as far as I understand it means that you can tune and have different maps using accessport instead of a UTEC or EcuTekTuner add-on to your ECUTek tune, which to date is the only multi-map tuner available...
Old Jan 19, 2005 | 09:06 AM
FLIWRX's Avatar
Former Sponsor
Car Info: 2002 WRX
The access tuner will allow you to fine tune a map that cobb already makes. So for example if you ware running cobb stage 2 the access tuner will allow you to more fine tune that map for your needs. Later on this year they will release access pro-tuner witch will allow cobb shops like us to completely make a map form the ground up and store in on the access port or flash your computer with it. So for example you could have a 91oct map and a 100oct race map custom made on the access port and switch between the two different maps. If you have any more question please let me know
Ryan
Old Jan 19, 2005 | 11:23 AM
02scubyroo's Avatar
Car Info: 2002 WRX
so bassicaly if i want to get my car tuned completely fromt he ground up i need to get ecutek..?
Old Jan 19, 2005 | 11:54 AM
FLIWRX's Avatar
Former Sponsor
Car Info: 2002 WRX
That or waite till the protuner comes and and you can still use your AP. It also depend what mods are on your car if you are close to what one of the stages are then the access tuner will most work for you. If you want a complete custome tune then pro tuner or ecutek are your ways to go
Ryan
Old Jan 20, 2005 | 03:39 PM
nic3krnnamja83's Avatar
so its like a utec but in a box?
Old Jan 20, 2005 | 03:51 PM
No. The advantage of the ProTuner is that it works like a reflash- it's not a piggyback. The disadvantage is, you don't want to pay for ProTuner, and the AccessTuner doesn't give you complete access to individual maps.
Old Jan 20, 2005 | 04:50 PM
^^^ ahh icicic thanks for clarification
whoring at its best
i need to make that a sig
Old Jan 20, 2005 | 04:54 PM
Or you could just drop it. Postwhoring is not a crime on i-club (see soggynoodles and black02wrx) but it's frowned upon in the tech forums.
Old Jan 20, 2005 | 05:33 PM
Donkey's Avatar
Car Info: 02' WRX
Plus the fact that with Accesstuner changes can be made on the fly tuning wise so you can instantly see the results of the tune where as Ecutek the vehicle has to be turned of,re-flashed,then dyoned again to see the effects of the changes.This is a process that takes a hell of alot longer and after the initiall tune ,is time you are paying for.
Old Jan 20, 2005 | 07:06 PM
sykosis's Avatar
Does anyone have any insight on wether COBB will ever release higher octane maps? I run 96 to 100 in my car for track so it'll be nice to have a more agressive map. Or is this will I be able to do this with the accesstuner.
Old Jan 27, 2005 | 05:42 PM
FLIWRX's Avatar
Former Sponsor
Car Info: 2002 WRX
As far as higher octane maps i have not heard anything to that effect from Cobb. One of the only ways that is going to be acomplished is by going to Cobb and getting the tune yourself. Or by wating till the protuner comes out haveing your computer flashed then. Pro-tuner does not require a access port. It will jsut be a ecutek style reflash. If you buy or have a accessport then you have the ability to switch the maps. So you dont have to have a AP to get a protuner flash.
Ryan
Old Feb 11, 2005 | 05:47 PM
04WRBsedan's Avatar
Car Info: 04 rally blue wrx sedan
So if I get a VF series turbo I can tune for the turbo based on cobb's 2.5 map? In other words I can get a VF34 and make changes to the map such as a Walboro FP or bigger top mount IC to maximize performance?
Loading...
Apr 10, 2014 07:35 PM
GarySheehan
Feb 7, 2009 11:00 AM
EQ Tuning
Sep 15, 2008 03:23 AM
jagstyle
Sep 2, 2008 10:08 AM
iNfEk
Apr 26, 2005 01:58 PM
