cali accessport map! awesome!
Old Nov 18, 2004 | 01:12 PM
gooder77's Avatar
Car Info: 2002 psm wrx
Has anyone used that Vishnu ECU reset "trick" for AP? He says it helps to get over the learning curve.
http://forums.nasioc.com/forums/showthread.php?t=302047
Old Nov 18, 2004 | 04:46 PM
Heavy Dan's Avatar
Car Info: '02 WRX, Aspen White, Stage 1 Cobb
i don't really buy into it personally. I was also told by a cobb dealer that thinkks it's kinda silly. the deal is that the ecu will become accustomed to your driving, car, etc. You can accelerate the process, but eventually the car is going to have to get reacquainted with how you really drive. No need to hurry it up... just let the ecu work itself out.
Old Nov 18, 2004 | 06:18 PM
Fatal Velocity's Avatar
Since a lot of you are using the AP I have been bnoticing bad gas milage lately, has anyone else noticed this or is my shoe made out of Led?
Old Nov 19, 2004 | 12:10 AM
Heavy Dan's Avatar
hmmm.... Maybe it's your shoe. I've always gotten the same bad gas mileage (19-20). But, on the other hand, I've found that I tend to drive faster since I got the AP. It's not that I am racing all of the time.... I just found that I have been coasting at 90 mph instead of 80 (as i did pre-AP). Obviously, 90 is less fuel efficient... so, in sum... at best, the AP has been more fuel efficient... at worst, it's been the same
Old Nov 19, 2004 | 11:41 AM
Chrisnonstop's Avatar
Car Info: 02 Silver WRX sedan. Eibach springs, Blitz NUR cat back, Rota 17" Attacks, Cobb AccessPort/DP
never pinged
What gas are you guys using when you're pinging? I have a 02 WRX at Cobb stage 2 and have never pinged. I'm using the standard 91 oct stage 2 map. I also use Chevron, Shell, or 76 gas. Just wondering.
Old Nov 19, 2004 | 02:21 PM
Heavy Dan's Avatar
i'd like to know too! I've never pinged before either. In fact, I've never been in a car that's pinged.... I wouldn't even know what to hear for... although... i imagine it sounds like: "ping" ...
Old Nov 19, 2004 | 03:16 PM
illusion's Avatar
Car Info: '09 accord, '14 2 seater chevy
I just guessed that mine was knocking because of the blatant knock retard I was getting. In the middle of a gear pulling strong, then *wham* a kick in the ***** and no more go fast. Since I switched to the cali stage 2 it's been one happy camper, although the wastegate noise is driving me insane, I wonder if it's so noisy due to a divorced wastegate DP(I need to either to the tightening trick or wrap that pig). Also the stg2 base map will give you 250 more rpms(a 7250rpm limit now). Overall I've been really happy with running Stg 2 with the cali map despite the horrid wastegate noise.
percula asked "oh hey, does anyone know if the access port can remove CEL's from uppipes, downpipes, etc?" Yes.. The AP base map disables many CELs.
For stg 2 here's the list
Originally Posted by cobb cali stage 2 map notes
CEL Codes Defeated [WHEN USING AS BASE MAP]
(** means new to latest revision):
P0037 - Rear O2 Sensor Heater Control Circuit Low **
P0038 - Rear 02 Sensor Heater Control Circuit High **
P0137 - Rear O2 Sensor Low Voltage **
P0138 - Rear O2 Sensor High Voltage **
P0139 - Rear O2 Sensor Circuit Slow Response **
P0420 - Catalyst System Efficiency Below Threshold
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas) **
P1312 - Exhaust Gas Temperature Sensor Malfunction **
P1544 - Exhaust Gas Temperature Too High **
Which is the cell codes that would happen from running limited or no cats.
lburrrna
Jun 28, 2006 05:26 PM
carletto
Jul 23, 2005 03:20 PM
