Boost creep
Old Mar 10, 2006 | 09:44 AM
Mr. Furley's Avatar
Car Info: MOPAR Baby!! yeeaaaahhh
Boost creep
Blast this 06!! haha i installed my TBE last night and sure enough the first drive out it overboosted and cut fuel! ack i hope they find out whats causing this problem soon
Old Mar 10, 2006 | 09:52 AM
STi deede's Avatar
Car Info: puppy hauler
port your waste gate.
Old Mar 10, 2006 | 09:53 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
yes.. its a lack of backpressure combined with an inefficient wastegate
same on the 04-05 that didn't have the larger exhaust housing
E:F:B
Old Mar 10, 2006 | 10:09 AM
soggynoodles's Avatar
A tune will help get rid of the problem.
cobb or ecutek
Old Mar 10, 2006 | 10:18 AM
BanHammer™
meh.. a tune will only do so much with a small wastegate
Old Mar 10, 2006 | 10:31 AM
Are you telling me he has a small wastegate?!?!?
What turbo are they using on the 06 wrx?
Old Mar 10, 2006 | 11:37 AM
Mr. Furley's Avatar
Think its slightly larger than the FXT turbo..... im planning on getting the AP as soon as possible. I dont think im gonna bother trying to port the stock turbo, if i take the time to remove it im just gonna put something bigger in its place i guess..... the good news is there was an up-pipe hiding in the foam peanuts i didnt pay for.......
Old Mar 10, 2006 | 12:13 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
A tune solves the boost creep issues on 99% of the cars. The last 1% requires an actual porting of the wastegate. Which TBE did you get?
Old Mar 10, 2006 | 12:44 PM
Mr. Furley's Avatar
I got the ssautochrome ebay TBE... it seems pretty decent and i didnt have any real fitment issues plus they sent me a free uppipe :-P
Old Mar 10, 2006 | 12:47 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
One thing to make sure is that the wastegate isn't being interferred with by the downpipe. Pop off the c-clip and make sure the wastegate swings freely. If it does, then you need to get an AP and tune asap.
Old Mar 10, 2006 | 12:58 PM
Mr. Furley's Avatar
Yeah i dont think the DP is interfering at all... i compared it to the stock before i put it on and if anything it should give the wastegate more room rather than less... my cel turned off after i started+turned off my car a few times so i went for another high speed test and i didnt hit overboost until mid 5th gear rather than end of 3rd/early 4th like it was before..?? maybe the ecu is starting to compensate?
Old Mar 10, 2006 | 02:26 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
The ECU could be adjusting slightly, but I would highly recommend not going WOT if you're seeing inconsistant boost levels like that. Hitting boost cut is also not too great for the drivetrain.
Old Mar 10, 2006 | 02:31 PM
Mr. Furley's Avatar
Yeah ive been going easy, i only really got on it cause i noticed the cel went out & wanted to see what would happen... the overboost shouldnt have any ill effects right? i know this turbo is pretty small for the engine could it even make enough boost to be dangerous?
Old Mar 10, 2006 | 02:42 PM
dz's Avatar
dz
Car Info: 1996 Mustang GT/2013 Outback Limited
It sure can, 8psi with the wrong tune could kill the engine. It is not too much pressure that causes the problem it is not being tuned for the conditions the car is seeing.
Old Mar 10, 2006 | 02:45 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Wow... something we can agree on
Top
