avc-r tuning questions for ya???
Old Apr 24, 2003 | 07:28 PM
madrex's Avatar
Car Info: 03 Rex: HKS, Injen, Apexi, Perrin, Rota
c'mon fellas, I'm tryin to work it here, I know there's somebody with the info out there just dyin to tell me... thanks
Here's my current setup:
MY 03 (U.S. spec)
HKS catback (perrin up and down pipe when they get em at Alta)
Injen CAI
AVC-R
initial duty cycle setting: 53
initial desired boost: 1.00
gear specific start duties
1st +2
2nd +1
3rd 0
4th -4
5th -5
N/S 255 (factory preset)
1st 120
2nd 075
3rd 050
4th 035
5th 025
F/B (feedback) all gears are preset at 3
learn gear is on in all gears
Initially I set the duty at 55 and the boost to 1.10
result: pretty high spikes normal around 1.17 or so with occasionals up to 1.24
three days later + the settings listed at the beginning + some serious flogging of the car on some back roads in all but the top of fourth and all of fifth gear have netted me some nice stable boost (.99-1.02) from around 2900 all the way to redline
questions:
1. how long will the unit continue to self learn, and if it always will, do I just turn off the learn when I'm happy or should I adjust the feedback settings (I don't know exactly what the f/b settings do??)
2. are my N/S settings right?
3. should I go in and notch the boost back a tad from 6500 to red?
4. do I go into the N/E just to choose what RPM's I get to set it at and then go to the graph to set the actual boost. do I need to change the duty cycle too?
5. for scramble I was thinking of pushing it up to 1.10 or 1.15, can I just set the boost for that as well or do I need to add some duty cycle?
thanks in advance for all your insightful answers. any help from bruthas who've done it before would be great.
EQ Tuning
Nov 2, 2017 05:05 PM
Christian.
Apr 17, 2007 02:34 PM
EQ Tuning
Feb 28, 2007 11:20 PM
WorldONE
Jul 9, 2006 03:40 AM
