AP or Utec
Old Aug 7, 2005 | 10:13 AM
faeker's Avatar
Car Info: 2003 WRX
Red face AP or Utec
Hey guys, I need some help here. I can get a utec used for 600, or I can get a new AP for 600. The only mod that I have is a turbo back. I don't really plan on much more until engine blows up (hello shortblock then). Maybe a tmic. anyway, the way things look so far, the AP seems my better choice. I just want to know what everyone else thinks.
Old Aug 11, 2005 | 04:24 PM
blue blurr's Avatar
Do you live near a tuner? If you do ide recomend getting the AP with Protuner, i have heard some funny things about the AP maps.
Old Aug 12, 2005 | 04:55 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
Get the AP. You'll be way happier.
Easier to have tuned and to keep your car's safeguards from the factory.
Old Aug 13, 2005 | 07:33 PM
BoostinEJ20's Avatar
+3 for accessPORT, then a protune.
Old Aug 13, 2005 | 11:04 PM
subabu05's Avatar
+4 for ap especially if you aren't near a tuner.
Old Aug 16, 2005 | 01:42 PM
faeker's Avatar
Car Info: 2003 WRX
got the ap.....love the hell out of it!!!
Old Aug 16, 2005 | 06:00 PM
WRX2ndregime's Avatar
Car Info: 2005blackwrx5spd
ap and protune +6
Old Aug 16, 2005 | 09:41 PM
thunder_sti's Avatar
Troll
What about the vishnu?
Old Sep 12, 2005 | 07:07 AM
Boost Addict's Avatar
+5 and +7 for the AccessPORT (because +5 wasnt mentioned)
vishpoo? what?
Old Sep 12, 2005 | 11:21 AM
subie OCD's Avatar
Car Info: 04 STi
Im glad I took my car there! I had it tuned on the dyno, and found out that under full parameters of the reflash, my engine was pinging (loud!) probably due to a dirty engine. Shiv then pulled timing so it wouldnt ping, and suggested that I have some maintenence done (spark plugs, fuel filter and seafoam) before pushing it any harder.
Ive done everything except seafoam, and the engine runs MUCH smoother, and I predict that when the seafoam cleans out any carbon deposits shiv will be able to tune it more aggresively and still be safe.
That being said, I would have it tuned on a dyno (ecutek or cobb protuner). If I had used an "off the shelf reflash" I could have been hurting my engine, I would rather pay a little more to have a safe custom map.
my 2 cents
Old Sep 12, 2005 | 11:28 AM
subie OCD's Avatar
Car Info: 04 STi
Originally Posted by Boost Addict
vishpoo? what?
any reasoning behind this?? I'd like to hear it
Old Sep 13, 2005 | 01:04 AM
Not really, a play on words at most. Although, I personally am not a favorite of his method of business... But thats just me, it happens to work for thousands of others.
I think the AP is a better choice for the fellow who started this thread, given his seeking simplicity and reliability with good gains...
COBB caters just that... and the only complaints I've heard about were people doing something wrong during "marrying" the AP to their cars... Besides that, it's set to run safely and reliably... It corrects all the factory programming, which were arguably timed to meet emission standards... And yes, it's true no 2 motors are identical, this however can be due to the stock ecu's 'learning' ability to adapt to a drivers needs... You'll find some stock motors dyno higher than others... Those who dyno higher were broken in more aggressively... the ecu has been used to more LOAD if you will... Once reset, the difference should be only miniscule.
So yes, with that out of the way... It's true that those with the luxury of getting their vehicle specifically tuned will find larger gains and safer operation with such gains... Those without that luxury, or who are quite sate with the gains an AP provides, should go the AP route, because those were programmed to provide gains (although not exactly as much as a custom tune) without sacraficing engine life... It COULD be stronger and more aggressive, but then it wouldnt be as safe as it is... COBB left themselves a large safety margin, theres more to be had with a custom tune, but hey... its safe and its an extra umph! Also, the AP now has protune, which allows pre-set maps or custom tunes if one wishes!
Old Sep 19, 2005 | 07:39 PM
faeker's Avatar
Car Info: 2003 WRX
went with AP...love it...but now I want a PTune.
Old Sep 25, 2005 | 01:45 AM
Troll
Well here I havent seen no one with an AP hit 12s at 1/4mile , the best ive seen was 13 flat from a 13.3-13.5...wow, thats not much, but then Ive seen the vishnu xede and they have shown good results,,, Im just saying this because i just have tbe on my sti and I run the same with some one who has the AP...thanks...
Old Sep 26, 2005 | 09:19 PM
Double Phister's Avatar
Father Time
Car Info: This aint a bag. It's a shipment.
A protuned AP can due everything a custom tuned ECUTek can do.
They are both reflashes of the stock ECU. No reason Shiv couldn't stuff his same maps into an AP.
