AP Stage 2 on an '02 WRX with UP, DP and STi Catback?
Old Feb 18, 2005 | 06:11 PM
bpang1's Avatar
Car Info: '04 WRX Wagon
Question AP Stage 2 on an '02 WRX with UP, DP and STi Catback?
OK so I threw on one of my friend's stock STi axle-backs on my otherwise stock car because I like the tip and am wondering if I can use the Accessport Stage 2 map if I have a Helix UP, DP and that exhaust.
Probably not but I just wanted to see if it was almost viable because I like the look and the only other close one to that is the Borla WRX Cat Back with single tip.
I primarily want to go stage 2 because of the CEL deletes and extra power.
Old Feb 19, 2005 | 01:29 AM
bpang1's Avatar
Bump
Old Feb 19, 2005 | 07:57 AM
IDAFC21's Avatar
all you TECHNICALLY need to run stage 2 is an aftermarket downpipe. so if you do have a helix up/down pipe w/ the sti exhaust, that would be fine for running stage 2. you could probably squeeze a little more power out of an aftermarket exhaust, but as far as requirements go for stage 2 youre good to go.
btw, ive got the full helix exhaust, LOVE it
Old Feb 21, 2005 | 03:30 AM
bpang1's Avatar
Yeah that's what I was hoping because of the fact that factory vs. stock cat-backs don't make a huge difference on other cars on the dyno anymore.
I guess it's because the OEMs are learning more about maximizing flow and minimizing noise. However, I guess it would make more of a difference if my car had a bigger turbo, more boost etc.
Hopefully it shouldn't be a big deal in my proposed setup.
Old Feb 24, 2005 | 10:30 AM
ryanjorunner's Avatar
You can definetly go with stage 2. Cobb says all you need is an aftermarket DP. you have that and more so go for it.
JourdanWithaU
Dec 6, 2012 06:35 AM
Speed Element
Mar 20, 2009 01:32 PM
brucelee
Mar 7, 2009 04:43 PM
STi_Mark
May 3, 2008 06:17 PM
lburrrna
Jun 28, 2006 05:26 PM
