Any reported problems with K&N drop in?
Old Sep 7, 2005 | 10:00 AM
sebring vetran's Avatar
Car Info: '05 WRX STi
I have searched the forums so if this is in the wrong place...sorry
I have recently heard of problems with the MAF while using a wet filter (K&N drop in). Some have reported that with time, some of the oil will accumulate on the MAF sensor causing serious problems and eventually needing replacement. If this is a true problem, is there a way to properly clean the MAF or is it such a sensitive piece we shouldnt touch it?
Old Sep 7, 2005 | 12:17 PM
Dice's Avatar
Car Info: 2002 WRB WRX
It has happened to some people, but if you buy a new k&n filter pre-oiled from the factory, it most likely wont happen. All the problems you hear of gunk building up on the MAF sensor was most likely because of people over oiling it when the clean it. Ive had one for around 10,000 miles and it hasnt cause me an problems. Removing the snorkus (look it up) and gettin a k&n drop in or perrin drop in filter is a very good effective mod.
Old Sep 7, 2005 | 12:26 PM
I did the snorkus a while back and just put the K&N drop in filter a few weeks ago, then heard about the gunky buildup and had second thoughts to put the paper back in. The over oilling does make sense. I still wonder if you can clean the sensor if it looks dirty. Maybe with a cotton swab?
Old Sep 7, 2005 | 12:36 PM
subie OCD's Avatar
Car Info: 04 STi
I just use the oem air filter cause its cheap and simple...and I would probably be one of the morons that over oils it. haha
Old Sep 7, 2005 | 07:20 PM
knight1833's Avatar
Car Info: 98/05 RSTi
the K&N works fine, just follow the directions when you clean it.
I've had one in for about 50K no problems at all
RelaxTampax
Hawaii Classifieds
Feb 3, 2014 12:04 PM
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
dub2w
Apr 20, 2004 03:55 PM
GQracerx
Subaru OEM Parts For Sale
Oct 20, 2003 09:59 PM
