Any ProDrive Stage 2 Kit Experience to Share
Old Nov 7, 2003 | 06:25 PM
subaruxtras.com's Avatar
Why would you buy it for $1500.00. when I sell them for $1270.00. Here is the latest dyno chart.
Mike
www.subaruxtras.com
Old Nov 11, 2003 | 09:12 AM
I have a set of instruction for the whole exhaust from the service manuals but it is over kill. I can fax them if you have a fax. Here what you need to do
1) remove muffler 2 bolts and 2 nuts
2) install new muffler 2 bolts and 2 nuts
3)remove the center section 4 bolts and nuts
4) remove the heat shields 8 bolts and nuts
5) put heat shields on new center setion 8 bolts
6) install new center section 8 bolts and nuts
now the intercooler
1)remove the 2 mounting bolt on top
2)disconnect the 2 hose on the left side
3) disconnect the hose on the right side of the ic
4) remove the 2 bolts on the bov
5) remove the clamp on the single eng of the y pipe and remove.
take out the intercooler and flip over and remove the y pipe.
I hope this helps most of my customer in stalls these kit in there driveway with ramps or jack stands
Mike
casualsurfer
May 3, 2004 03:24 PM
rustokman
Feb 29, 2004 08:18 PM
useful
Jan 23, 2004 01:46 AM
