Air Filter cover problem
Old Feb 26, 2003 | 03:58 PM
Peaty's Avatar
I've the same problem w/ every scooby I've owned. The only way I was able to be sure it was properly closed was this:
http://www.scoobymods.com/forums/sho...=&threadid=187
Old Feb 26, 2003 | 07:11 PM
WillysPU's Avatar
Car Info: 03 Blu WRX, vf 34, headers, catless, gc coilovers, f/r sways
Lightbulb
There are 2 tabs on the drivers side of the filter cover that need to be inserted into the box before you can close the box so the clips will fit correctly.
Jim
What would Scooby do?
Old Feb 26, 2003 | 11:47 PM
stayfido's Avatar
If the airbox isn't fully seated with a K&N will this do much harm? I am in the same boat being unable to seat the airbox lid properly.
Old Feb 27, 2003 | 06:00 AM
Peaty's Avatar
Yes it will let dirty air bypass. That's why I use the procedure in my link above. It's not really that hard to time consuming but you can be positive it's seated.
Old Feb 28, 2003 | 09:07 PM
ImprezaRSDriver's Avatar
What filter part number did you get because K&N makes a proper sized filter, the 33-2232. I have no problem getting any filter into my box. There is a way to get it in an have it seal properly.
What you do is first put the tabs into the lower position of the box. Then slide the air filter in and as it is going in, close the upper portion of the box like a pacman mouth and it should sit properly at the end. You may have to wiggle the filter and box around but it should be able to sit properly without any problems.
Choku Dori
Jul 6, 2010 07:02 PM
Dark Industries
Engine and Drivetrain
Feb 28, 2006 03:27 PM
se0ul
Jun 2, 2005 01:59 AM
Peaty
Aug 20, 2003 07:01 PM
