AccessPort - Valet mode
Old Apr 29, 2009 | 09:27 PM
I did a search on here and nazioc but did not come accross what I was looking for. Might have overlooked it, so if someone has a link
Ive got APv2. Im taking my car in Monday to the body shop and it will be there for 3-4 days. I want to put the car in valet mode when I drop it off.
Does anyone know how to do so, or have a link?
Edit: Thanks ICB
http://www.accessecu.com/accessport/...03WRXMaps.html
Old Apr 29, 2009 | 09:28 PM
VRT MBasile's Avatar
"Valet Mode" is just a specific "Valet" realtime map. It turns off the boost and sets the rev limiter at 4k
CliffNotes: Load the Valet realtime map
Irish_car_B0mb's Avatar
did you try the cobb website, it seems pretty self explanatory
Old Apr 29, 2009 | 09:30 PM
i searched cobbs site for "access port valet mode" and didnt get anything
Old Apr 29, 2009 | 09:47 PM
WRrex's Avatar
Car Info: 2002 something
I would like to know as well. Anyone have a link to it?
please see Post #2
Old Apr 29, 2009 | 09:48 PM
towards the bottom 3rd or 4th from the bottom
Old Apr 29, 2009 | 09:52 PM
WRrex's Avatar
please see Post #2
Why do you have to be an *** about it
Old Apr 29, 2009 | 09:54 PM
Because the answer was presented prior to the re-asking of the question. That's one thing i have little patience for.
Old Apr 29, 2009 | 10:02 PM
Awesome! Thanks ryan
heres the info on the map
http://www.accessecu.com/accessport/...ode%20v130.pdf
Old Apr 29, 2009 | 10:10 PM
glad i could help
Old May 5, 2009 | 04:32 AM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
NEGATIVE. DO NOT RUN THE REALTIME MAP!!!!! The realtime map can be cleared and turned off by unhooking the battery to clear the ecu, it will also be removed if they kill the battery.
First thing that comes to someones mind when a car isn't running right is to clear the ecu and guess what. They probably will and then they will have a very fast car to play with.
My suggestion is to load the valet base map when you get there! The base map can't be removed by unhooking the battery.
Old May 5, 2009 | 07:29 AM
VRT Gump's Avatar
1. plug in AP
2. connect two green plugs that are under steering wheel, may have to look a little but they are there
3. flash ECU with valey mode
4. disconnect green plugs
5. unplug AP
6. turn keys over to body shop
7. wait time to have them fix car
8. pick up car
9. plug in AP
10. connect green plug
11. reflash with other map
12. unplug green tabs
13. drive home in nice clean fixed car
make sure car is on during the reflash also. if you have any other questions please refer to the instructions that came with the AP.
Old May 5, 2009 | 10:12 AM
Originally Posted by VRT Gump
1. plug in AP
2a. Plug in blue connector (2002) or white (2003-up)
4a. disconnect blue/white connector
5. unplug AP
8. pick up car
9. plug in AP
Fix'd
But yea thats exactly what I did yesterday
debelle wrx
Jul 18, 2007 03:44 PM
Antonio85
Aug 7, 2005 04:06 AM
RshaoKh
Apr 14, 2005 03:40 PM
wiredwrx
Dec 10, 2002 11:52 AM
