Winter prep your car with fresh lubricants from RallySport Direct!
Old Sep 30, 2013 | 02:58 PM
RallySportDirect's Avatar
Former Sponsor
Car Info: GC,GF,GD,GR,GH
Winter Prep your car with the correct lubricants from RallySport Direct!
As the winter season approaches, extreme cold temperatures can take a toll on your vehicle. It is always a good idea to update all the fluids in your car whether if you’re winter prepping or not. Keep all your internally lubricated parts working well and properly maintained with a great selection of oils, coolants, filters, and such available at RallySport Direct!
ENGINE OILS
Red Line
Since 1979, Red Line Synthetic Oil Corporation has grown to manufacture more than 100 quality products, including motor oils, gear oils, assembly lubes, fuel additives, and its popular WaterWetter cooling additive for the automotive, motorcycle, marine, and industrial markets. Based in Benicia, California, Red Line has a reputation with racers and enthusiasts alike for creating products that perform and protect better than any on the market, regardless of price.
Red Line 5W30 Motor Oil 1QT
$10.95
Red Line's synthetic motor oils are designed to provide the highest protection, cleanliness and superior drain intervals with the lowest friction for your gasoline, diesel, motorcycle or marine engine. Red Line uses the most stable components available and formulate their products for wear protection and friction reduction across a wide range of engine operating conditions. Red Line's products are unique because they contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat.
The Red Line 5W30 provides the quickest starts and fastest oil pressure rise. Will reduce turbo lag and provides more power and best economy in an engine in good condition. Replacement for OE factory-fill oils in passenger cars and most light trucks. Thicker oil film at operating temperature than a petroleum 10W-40. Best choice for engines operated in extreme cold weather.
Red Line 20W50 Motor Oil 1QT
$10.95
The Red Line 20W50 is the ultimate high-temperature protection engine oil that is recommended for street use. Good for engines that regularly run very high oil temperatures. Best for engines that run large clearances such as air-cooled engines or large-displacement, all-out racing engines that see occasional street use. Provides 25% more viscosity in bearings than petroleum 20W-50s. Not recommended for use in cold climates where temperatures are at or below 10 F or -12 C. Not recommended for street use in production engines that see sustained oil temperatures below 225 F (those engines should use Red Line 10W-30 or 10W-40).
Red Line 10W30 Motor Oil 1QT
$10.95
Red Line's synthetic motor oils are designed to provide the highest protection, cleanliness, and superior drain intervals with the lowest friction for your gasoline, diesel, motorcycle or marine engine. Red Line uses the most stable components available and formulate their products for wear protection and friction reduction across a wide range of engine operating conditions. Red Line's products are unique because they contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat.
The Red Line 10W30 has Great all-weather viscosity grade for gasoline engines in cars and light trucks that are driven on the street on a daily basis. More power and economy while providing thicker bearing oil films at operating temperature than a petroleum 10W-40. Best choice to replace a 5W-30 or 10W-30, petroleum-based or other-brand synthetic oil if maximum durability is preferred. Acceptable for engines that are occasionally operated in extreme cold weather.
CONTINUED
Motul
Motul Fluids are widely used in the racing industry. Used in the Subaru WRC car that you know, Motul Fluids can handle the extremities and abuse of a high performance vehicle as well as providing the best performance and protection for your everyday driven vehicle.
Motul 300V High RPM 0W20 Motor Oil 2.1QT
$36.89
100% synthetic racing motor oil based on ESTER Core® technology. Through technical partnerships with most prestigious teams of car racing, MOTUL has developed a wide range of lubricants for Racing and Sport cars. The 300V motorsport line improves performance of the latest generation engines along with high protection against wear, oil pressure drop and oxidation due to high temperature. Power. Low engine dilution.
For decades MOTUL has developed high performance synthetic Ester based lubricants. By selecting esters over other high performance synthetic base stocks and combining them with an innovative additive package, MOTUL has created a perfect synergy. This most advanced ESTER Core® technology allows maximum power output of the engine without compromising reliability and wear.
Type of use: Qualifying / Acceleration / Sprint
GEAR OIL
Red Line LightWeight ShockProof Gear Oil 1QT
$15.49
Red Line's ShockProof Gear Oil features a unique lubricant containing a suspension of solid microscopic particles as an extreme pressure agent--unique solid dispersion which cushions gear teeth to help prevent tooth breakage and allows the use of lower viscosities.
Acting like a liquid grease, the viscosity characteristics of ShockProof Gear Oil allow the lubricants to resist throw-off and provide the protection of a greater film thickness with relatively light fluid viscosity, offering a "best of both worlds" balance of low drag and superior protection.
ShockProof Gear Oil products work in a variety of differential and transmissions, however, should not be used with pumps, filters, and with small lines--these fluids are designed wet sump or splash type lubrication.
The Red Line LightWeight ShockProof Gear Oil is a unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures. Similar to a 75W140 gear oil, but with the lower internal friction of an SAE 30 motor oil.
Red Line MT90 Manual Transmission Lubricant 1QT
$14.49
Red Line Oil's MTL and MT-90 are designed to provide excellent protection and improved shiftability for manual transmissions and transaxles, having cured the problem of hard shifting in thousands of transmissions with shifting troubles. How? They have the appropriate coefficient of friction for most manual transmission synchronizers (many gear oils, engine oils, and ATFs are too slippery for proper synchro engagement). And, the wide viscosity of MTL and MT-90 allow proper shifting over the entire temperature range which the transmission will experience.
The synthetic base oils used have a very high viscosity index which provides relatively constant viscosity as temperature changes. MTL is a low 70W at very low temperatures and a high 80W, nearly an 85W, at elevated temperatures, providing adequate viscosity to prevent wear and deaden gear noise. MT-90 is a thicker 75W90 version of MTL. The shear stability and oxidation stability of these products are excellent, thus the physical characteristics of Red Line MTL and MT-90 will change little with use.
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil that's slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
Motul Gear 300 75W90 Gear Oil 1QT
$18.91
Ester-based and 100% synthetic, GEAR 300 is formulated for gearboxes and rear axles, especially for competition cars - racing circuit, rallies and endurance trails. GEAR 300 is test proven effective to extreme pressure resistance in all types of cars and under all types of uses. GEAR 300 extremely high lubricity reduces friction. It also offers anti-wear, anti-corrosion and anti-foam capabilities.
LIMITED SLIP OIL
Motul 90 PA Limited Slip Differential Oil 2.1QT (Subaru R180 Rear Diff)
$25.08
This is an Extreme Pressure Lubricant for Limited Slip Differentials.
Specially formulated for limited-slip differentials : Racing cars, Passenger Cars and Industrial applications.
Special formula includes a friction modifier for clutch-pack or plate type differentials to prevent dragging of discs.
Cusco LSD Oil 1 Liter API/GL5 80W-140
$40.85
This oil is recommended when changing the oil on your Cusco LSD. This gear oil has the proper additives in the oil to prolong the life and performance of your LSD.
OIL FILTERS
Subaru OEM
Subaru OEM Products are the exact same part numbers and products that you get at the dealership. Here you will find a full array of OEM Subaru Replacement Products. No more trying to find time to run down to the dealership
Subaru Genuine OEM Oil Filter Most Subaru Models
$6.59
We recommend using the Subaru Genuine Oil Filter in your Subaru for your maintenance needs. Recommended for replacement with every oil change. Use the best oil filter to keep your motor running at its best for a long time.
Subaru OEM Oil Drain Plug Gasket
$0.96
This is a Genuine Subaru OEM part. This gasket goes on your oil drain plug to ensure a tight leak-free seal. Recommended for replacement anytime the drain plug is removed.
KN
K&N Engineering, of Riverside, California, is the inventor and leading innovator of reusable cotton gauze filter technology for automotive applications. From humble beginnings as a family run business over 40 years ago, K&N Engineering, now a truly global company with offices in the U.K. and the Netherlands, continues to exist as a family owned business with an enthusiast mindset and a direct connection with motor sports that carries over throughout all levels of management and manufacturing.
K&N Oil Filter HP-1008 Many Makes (inc. 2004-2014 Subaru WRX / STI)
$11.51
Originally developed for demanding race applications, K&N's Performance Gold® Oil Filter has become a favorite among consumers for its durability and easy removal. Featuring a 1” nut welded to the top of the canister so they can be easily wrenched-off with a standard tool. To satisfy the demands of racers, K&N oil filter has many features over and above the requirements of most vehicles. Use of thicker canister walls for extra strength and durability which reduces the risk of damage from loose rocks and debris. The drilled hole on the nut provides for safety wire attachment. K&N oil filters also use a resin impregnated cellulose filter media. This allows for higher flow rates while providing outstanding filtration.
DRAIN PLUGS
Greddy Magdrain Magnetic Oil Drain Plug M20 x 1.5 Subaru / STI Rear Diff 2008-2014
$17.10
The GReddy Magnetic Oil Drain Plug has a powerful 5000 gauss neodymium magnet in the top. The neodymium magnet is one of the most powerful magnets on the market. By using the "GReddy Magdrain" plug, you can help reduce the amount of abrasive materials in your engine, while extending the life of your engine.
Due to a different oil pan design, some Subaru OEM oil pans have a internal screen on the inside of the pan where the drain plug sits. If the screen exists the tip of the drain plug will be to long and will not be able to sit flush in the pan. There is no way to tell if you car has this screen aside from using a flashlight and checking the drain plug hole during an oil change.
A couple of years ago (Late 2010) Subaru began using a new size engine drain plug on some models from an M20 to the smaller M16X1.5X12. If the wrench required to take off the plug is 14mm then your car needs the M16 plug.
Dimple Magnetic Oil Drain Plug M20x1.5 Subaru / STI Rear Diff 2008-2013
$34.95
The simple fact is the oils in your car work best when they are uncontaminated. Continuous friction of moving parts creates tiny metal particles that are measured in microns. A micron is one millionth of a meter. 25 microns is .001”… yeah, one thousands of an inch. Oil filters can remove particles larger than 35 microns, but what happens to the rest? They get circulated back thru your engine wearing down your parts even more.
That is where Dimple comes in. Their magnets are the strongest high temperature grade neodymium magnets in the world. They simply rip those smaller particles out of the oil stream. Regular neodymium magnets start to lose their magnetism at 175f but Dimple’s have been proven to hold their magnetism at well over 300f.
Project Mu Magnetic Oil Drain Plug M20x1.5 Subaru / STI Rear Diff 2008-2014
$31.00
The Project Mu Magnetic Oil Drain Plug helps extend the life of your engine. The magnetic plug will help to keep excess metal particles that are created during the normal operation of your engine from floating around in your oil causing premature wear that can lead to failure.
BRAKE FLUID
Motul RBF600 Brake Fluid Synthetic DOT 4 500ml
$17.84
The Motul RBF600 Brake fluid is 100% synthetic fluid for hydraulic-actuated brake and clutch systems. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. The elevated boiling point of RBF 600 being at 312 C / 593 F enables effective braking even under the extreme conditions of competition. The very high wet boiling point (216şc / 420şF), is superior to conventional brake fluids and provides a particularly efficient braking system in rain and retards the apparition of vapor lock. FMVSS 116 DOT 4 / SAE J 1703 / ISO 4925. The RBF600 Brake fluid is sold per bottle. 2 Bottles are recommended for a full system flush.
ATE Type200 Brake Fluid DOT 4 1L
$18.99
ATE Typ200 Amber Brake Fluid is designed to excel within the extreme demands made on a race vehicle or by high performance drivers and exceeds all DOT4 standards. It is compatible with and will mix well with most DOT3, DOT4 or DOT 5.1 fluids.
The formula offers a minimal drop in boiling point due to outstanding water binding properties resulting in a long-lasting fluid that may not need to be changed for up to 3 years under normal highway driving conditions. Products with a lower wet boiling point have to be replaced considerably more often (e.g., DOT3 products should be replaced annually). The overall high dry and wet boiling points make this fluid an excellent choice for street driven vehicles, too, where brake fluid is flushed less frequently than that in race-driven vehicles.
POWER PACKAGES!!
Red Line Subaru STI Power Pack
$129.02
Reduced turbo lag, smoother shifting, improved fuel economy and cooler operating temperatures are among the benefits of the STi PowerPack from Red Line Oil. Dyno testing shows significant horsepower and torque gains all over the power range.
Included in the kit are 5 quarts of 5W30 motor oil, 5 quarts of 75W90 NS gear oil for the transaxle, 1 quart of 75W90 gear oil for the rear differential, 1 bottle of WaterWetter for the radiator, and 1 bottle of SI-1 Complete Fuel System Cleaner.
[img]
Red Line Subaru WRX PowerPack
$132.99
Reduced turbo lag, smoother shifting, improved fuel economy and cooler operating temperatures are among the benefits of the WRX PowerPack from Red Line Oil. Dyno testing shows significant horsepower and torque gains all over the power range.
Included in the kit are 5 quarts of 5W30 motor oil, 4 quarts of 75W90 NS gear oil for the transaxle, 1 quart of 75W90 gear oil for the rear differential, 1 bottle of WaterWetter for the radiator, and 1 bottle of SI-1 Complete Fuel System Cleaner.
FREE UPS GROUND SHIPPING WITH ORDERS ABOVE $200 IN THE LOWER 48
Old Nov 4, 2013 | 11:10 AM
queeg9k's Avatar
Winter is here once again so it is a great time to make sure your car is prepped for the change in temperature. Can you guys recommend a viscosity for a vehicle spending the season in the Tahoe basin?
Old Nov 4, 2013 | 12:09 PM
Former Sponsor
The transmission fluid will remain the same, but for motor oil I typically suggest running a 5W30 if temps are around freezing, or even as low as 0W30 if you are starting your car from a dead cold around 0 degree range.
Kirill
RallySportDirect.com
RallySportDirect
Aug 26, 2015 08:10 AM
RallySportDirect
Aug 20, 2015 09:10 AM
chimchimm5
May 21, 2012 06:07 PM
Group B
Oct 27, 2004 12:11 AM
RallySportDirect
Vendor Group Buys/Specials
Jun 1, 2004 02:08 PM
