Perrin Everything! Sun Auto, Titek, Greddy & Tanabe Catbacks, More!
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
SpeedElement is your Perrin Authorized Dealer!!
--All Perrin Hoses come in RED, BLACK, or BLUE. Choose color when ordering!--
New Perrin Turbo KITS!
When basic bolt ons won’t do or you have simply stalled out with the performance of the factory turbo then Perrin's Rotated Turbo Systems are the place to go! With kits that range in power totals from 350 WHP to more than 600WHP we have any boost junkies needs covered.
All Kits include: stainless steel up pipe and down pipe, Tial 44 wastegate, a new complete intake system, oil and water lines,and the Turbo.
GT3071R kit $3179 shipped!
GT3076R kit $3199 Shipped!
GT3582R kit $3289 shipped!
Perrin FMIC Kit: 02-07 WRX/STI
The PERRIN Performance Front Mount Intercooler is huge. Delivering higher cooling capacity and a significant reduction in intake temperatures. Cast aluminum end tanks and a bar-and-plate design offer smooth airflow and even pressure while retaining the stock bypass valve-mounting flange. Polished: $1,259 shipped! Signature (red) or New Stealth (black): $1305 Shipped
Perrin Blow-thru Boost Tube: 02-07 WRX/STI
PERRIN Front Mount Intercooler users can now get a more accurate charge temperature reading and run a VTA BOV with no problems! Instead of measuring the Mass Air Flow (MAF) and air temperature before the turbocharger, the PERRIN PerformanceTM Blow-Thru boost tube moves the mass airflow sensor to the boost tube before the throttle body. The placement of this does many good things like allowing your ECU to read the actual charge temp the engine sees, which eliminates any need for a Cold air intake.
MSRP:$219.99, YOUR PRICE $199 FREE SHIPPING! Polished, Signature (red) or New Stealth (black)
PERRIN Performance™ TMIC
Perrin TMIC Fits 04-07 STI. We have these for 08+ WRX too! These bar and plate cores offer more surface area per square inch than cheap tube and fin choices from our less worthy competitors and the overall size is more than 200% of the OEM unit!
MSRP:$869.99, YOUR PRICE $785 FREE SHIPPING!
**For 02+ WRX add $140 for Y-Pipe kit.**
Perrin Intakes!
PERRIN Performance™ Big MAF
The PERRIN Performance™ Big MAF intake system is designed to prevent the Mass Air Flow output value from being pegged on heavily modified WRX engines. When using the factory MAF sensor and adding large amounts of boost the stock MAF sensor will max out and not allow additional compensation for air flow.
MSRP:$229.99, YOUR PRICE $209 FREE SHIPPING!
Perrin Short Ram Intake
Manufacturing one of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then their competitors.
MSRP: $199.99, YOUR PRICE $180 FREE SHIPPING!
Perrin Cold Air Intake
One of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then our competitors.
MSRP: $314.99, YOUR PRICE $285 FREE SHIPPING!
Perrin Panel Filter
Add horsepower and torque without replacing the entire air box assembly.
The PERRIN Performance dual stage drop in panel filter provides maximum power gains while removing harmful particulates from the air charge.
This is a direct replacement for the factory panel air filter. Comes pre oiled and ready for installation.
Fits: WRX, STi, Forester XT and Baja!
$39 FREE SHIPPING!
Perrin AFTA-MAF Tube
Simple to install and easy to appreciate, the AFTA-MAF™ is an eloquent compliment to every engine bay. Replaces the factory corrugated rubber hose between the inlet tube and air box.
MSRP, $79.99, NOW $72 FREE SHIPPING!!!!
Perrin Turbo Inlet Hose Kit. We have them for 02+ WRX/STI AND 08+ WRX
Fits: IHI VF series turbo, FP Green, and etc..
MSRP $209.99, YOUR PRICE $190 Free Shipping!!
PERRIN Performance™ Subaru 04-06 STI Fuel Rail Kit
This kit solves all fuel distribution problems. Perrins fuel rails direct fuel to both banks of cylinders and to the fuel pressure regulator. Even fuel distribution is achieved through the PERRIN™ design guaranteed! PERRIN Performance™ fuel rails are specifically designed for the 04-06 Subaru STI side feed injectors to retain correct fuel injector alignment. THE PERRIN FUEL RAIL KIT INCLUDES: BILLET ALUMINUM RAILS FUEL PRESSURE REGULATOR MOUNT STAINLESS LINES AND FITTINGS.
MSRP, $409.99, NOW $369 FREE SHIPPING!!!!
Perrin Crank Pulley
Weighing in at 1.2lbs, this pulley is more then 4 lbs lighter then the stock crank pulley. The Perrin pulley is not under driven and will not affect the life of your engine!
Fits: WRX, STi, Forester XT and Legacy GT
MSRP $134.99, YOUR PRICE $125 FREE SHIPPING!
Perrin Intercooler Hose Kit 02-05 WRX or 06-07 WRX
Increase airflow over stock intercooler hoses with PERRINs redesigned air passages insuring equal boost to all areas of any top mount intercooler.
MSRP $154.99, YOUR PRICE $140 FREE SHIPPING!
Perrin Radiator Hose
Made of high gloss vividly colored silicone, Perrin radiator hoses are an excellent compliment to your existing Perrin intake system or inlet hose.
Fits: WRX and STi
MSRP $149.99, YOUR PRICE $135 FREE SHIPPING!
Perrin Equal Length Header
Constructed from 321 stainless steel and 1/2 flanges the header is designed to withstand the most punishing levels of heat your engine can dish out. Fits all 2002-2007 models. (2.0 WRX models will require a STi type oilpan for clearance.)
MSRP $749.99, YOUR PRICE $679 FREE SHIPPING!
Perrin Front and Rear Section Down Pipes Availible too for BOTH 02-07 WRX/STI AND 08+ WRX!
YOUR PRICE $PM For Pricing FREE SHIPPING!
---Catback and Down Pipe Super Sale!! ---
--Invidia Cattless Down Pipe (Divorced Wastgate) 02-07 WRX/STI--
$355 shipped One of the highest horsepower dps on the market!
--Titek Catless Down Pipe!!! 02-07 WRX/STI--
$225 shipped
--Tanabe Catless Down Pipe! 02-07 WRX/STI--
$345 shipped
--Megan Racing Catless Down Pipe! 02-07 WRX/STI --
$175 shipped
--Megan Racing Catless Down Pipe! 08+ WRX --
$220 shipped
--CATBACK SALE--
GReddy Racing Ti-C Cat-back. - $559!!
Greddy Evo2 catback - $579!!
Perrin New Stealth catbacks!!
$725!! for either "street" (quiet) or "sport" (evil)
Perrin Polished Street or Sport catback - $699!!
Perrin Dual Tube (single tip) Catback - $759!!
Perrin Sport Twin Tip - $699!!
Apexi PS Revolution Catback - $1015 Shipped
Apexi WS2 Catback - $569 Shipped
A'PEXi Ex Ti Catback - $985 Shipped
A'PEXi GTSpec Catback - $680 Shipped
Apexi N1 Catback - $540 Shipped
Tanabe Catbacks in stock! Big power without the noise! 95bd and below Pics are in post #19
Concept G Blue Turboback: 02-07 WRX/STI -$1070 shipped
Medalion Touring: 02-07 WRX/STI - $715 shipped
Medallion Concept G: 02-07 WRX/STI - $756 shipped
Visit our website for more details on all of the Catbacks we carry! http://www.speedelement.com/index.ph...0&limitstart=0
More Great Parts!!
Hondata Intake Manifold Gaskets!
By using these gaskets it significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power! - $65 shipped
Walbro Fuel Pumps!
Walbro 255 lph Fuel Pump - $90 shipped
Add Walbro WRX Setup Kit to the pump for - $15 *not sold separately*
Greddy Timing Belts!!
Engineered to increase heat-resistance, flexibility and durability, GReddy Extreme Timing Belts reduce the chances of cracking from heat, inconsistent timing from stretching and skipping or snapping. Improvements in materials and construction lead to a more reliable belt that will be more consistent and last longer. For EJ20 motors.
$168 Shipped!! Order here: http://www.speedelement.com/index.ph...mart&Itemid=38
Sun Automobile!!
Hyper Ground System - Cyber Speed
Giving your car a more efficient ground will help to pull out its full performance potential! The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals.
$PM for Pricing!
Hyper Force System
We have seen a 10hp gain from adding ONLY this system on our Dyno Dynamics Dyno!!
Click here for dyno the dyno chart!
$BLOW OUT PRICING!! Includes WRX harness!! PM for Price!!
Hyper Voltage System - Cyber Speed
Designed to stabilize voltage in your vehicle for maximum battery efficiency and allowing its full potential to be released.
$244 Shipped!
Check out ALL of the Sun Automobile products we carry as well as more info and pix in our online store!! http://www.speedelement.com/index.ph...mart&Itemid=38
BEATRUSH!
Beatrush Air Intake Box (includes Apexi cone filter)02+ WRX/STI - $259 Shipped!
Beatrush Air Funnel. Allows cooler air into the stock airbox from the fender well - 02+ WRX/STI - $165 Shipped!
ARC!!
ARC Induction Box 02+ WRX/STI - $420 Shipped!
ARC TI Pulley Cover - $170 Shipped!
ARC Round Titanium Shift **** - $109 Shipped!
ARC Blue Oil Cap - $100 Shipped!
As always you can check out our website for more items as well!! We are adding NEW 08+ WRX Items daily!!
If you order by paypal: sales@speedelement.com please add 3% fees or give us a call at 510.226.8822
FREE SHIPPING only applies to lower 48 states.
*CA Residents please add local sales tax* Paypal add 3% fees
Rob
Speed Element/MPJ Performance
www.speedelement.com / www.mpjperformance.com
44875 Industrial Drive Unit B
Fremont, CA 94538
Perrin Intakes!
Perrin Panel Filter
$39 FREE SHIPPING!
Perrin Crank Pulley
Fits: WRX and STi
$225 shipped
$345 shipped
$175 shipped
$220 shipped
--CATBACK SALE--
More Great Parts!!
Walbro Fuel Pumps!
Sun Automobile!!
$PM for Pricing!
Hyper Force System
$244 Shipped!
BEATRUSH!
ARC!!
Rob
Fremont, CA 94538
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
Speed Element
Nov 6, 2007 11:09 AM
Speed Element
19
Jun 7, 2007 11:15 AM
DCH Motorsports
Jan 19, 2007 03:40 AM
gruppe-s
May 9, 2006 01:43 PM
