Big HKS, Greddy, Perrin savings! Helix Ti Catbacks, Injectors, VF34s , Motor Mounts.
Old May 9, 2006 | 12:20 PM
gruppe-s's Avatar
Injectors:
Helix Power 660cc Injectors for WRX + Walbro 255L FP and setup kit - $539 Shipped!
$459 Shipped for just the Injectors!
- Ideal for VF series and PE size turbos on WRXs
- 340WHP Capable
- Will work on the 06 WRX
Helix Power 820cc Injectors for WRX + Walbro 255L FP and setup kit - $549 Shipped!
$479 Shipped for just the Injectors!
- Ideal for large turbos on WRX: Green, 20G, GT30R, etc.
- 510 WHP Capable
Helix Power 860cc Injectors for STi + Walbro 255L FP and setup kit - $565 Shipped!
$495 Shipped for just the Injectors!
- Ideal for 20G, Green, Red, GT30R, GT35R, etc.
- 550WHP Capable
Gruppe-S V2 Manifold Crucial Racing 2000 Coating - 02+ WRX / 04+ STI - $599 Shipped!
The Gruppe-S manifold is a 4 to 1 manifold designed to provide extensive midrange and top-end power gains. Our manifold features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. Strong gains in both HP and torque can be expected with the addition of the manifold, especially with high horsepower applications. The Jet Hot 2000 outside coating eliminates heat loss thus virtually eliminating low end power loss (compared to stock headers). These are the best coated headers we have ever seen; the coating is evenly applied with no bubbles and is absent from all bungs and threading. Includes all necessary gaskets.
The Crucial Racing 2000 outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly. More information on the coating is available here:
http://www.crucialracing.com/products/coating.php
Turbo Packages:
IHI VF34 + STI 565CC Injectors OR Helix Power 660cc Injectors + Walbro Fuel Pump
-375HP Capable on a WRX (with proper tuning)
-Includes Genuine IHI VF34
-Genuine STI 565cc Pink Injectors OR Helix 660cc Injectors
-Walbro 255l/h Fuel Pump
$1249 shipped!!!
IHI VF34 + STI 565CC Injectors OR Helix Power 660cc Injectors + Walbro Fuel Pump+Ecutek Reflash
-Send us your ECU and we'll reflash it and we'll overnight it back to you
$1949 shipped!!!
IHI VF34 + STI 565CC Injectors OR Helix Power 660cc Injectors + Walbro Fuel Pump + Installation + Ecutek Reflash + Custom Dynotune
-Please call to schedule an appointment
$2299 shipped!!!
Helix RNA Series Valvetrain and Cams- 2001+ Subaru Impreza EJ20 (non-AVCS) - $999 shipped
The Helix RNA camshafts and valvetrain are designed specifically for high power Subaru applications without sacrificing drive-ability and streetability. The RNA cams work well on the 2.0L platform, with a minor reduction in low end torque while providing truly impressive mid and top end power gains of over 20+ whp, and truly come alive on larger 2.2 or 2.5 liter applications by providing the extra intake and exhaust that the larger displacing engines need.*
*Helix Valvetrain is recommended for Helix Cams.
-SPECS: 264 Duration, 9.6mm Lift,Titanium Retainers, Dual valve spring, with spring seats
-APPLICATION: EJ205 / EJ207 Non-AVCS only
-RECOMMENDED MAXIMUM REDLINE: 8500RPM (w/ Helix valvetrain and supporting bottom end only)
-This cam and valve train package in the 2.0L WRX heads w/ a 2.5L SB make peak power numbers that are actually better than many of the 2.5L STi motors that we have tuned with similar supporting mods.
Helix RNA Series Cams- 2001+ Subaru Impreza EJ20 (non-AVCS) $519 shipped
While it is highly recommended that these cams be used in conjunction with the Helix Valvetrain, they can also be used with your stock valve train (which allows for 10mm of lift).
Gruppe-S Forged Connecting Rods for EJ20T (WRX or JDM STi) - $349 shipped!!!
These are super high quality forged steel connecting rods made by a famous JDM aftermarket manufacturer (please e-mail for this info). They will fit in any 2.0L WRX motor (including JDM STi motors). These would be an excellent rod choice for anyone building a 2.0L motor and should support well over 600 WHP. These rods feature ARP L19 rod bolts which are widely considered to be the best on the market. At this price, there is absolutely NO REASON not to use these rods if you're building a 2.0L motor.
-Very high quality forged steel connecting rods
-Manufactured by a world renowned JDM company - PM FOR MORE INFO
-Use ARP L19 con rod bolts (regarded as the best on the market)
-Super cheap blow-out price for super high quality part!
Gruppe-S Oil Cooler Kit - $499 Shipped!
This Oil Cooler kit was introduced to the public after testing several iterations on Brian Lock's USTCC race car in the deserts of Arizona. The stock WRX and STi lack an oil cooler and running any turbo charged motor hard puts an extreme load on the motor's cooling systems and fluids. Keeping your oil cool not only prolongs the life of your oil but more importantly, it prolongs the life of your motor. This is one of the most overlooked upgrades on the WRX / STi and we feel that anyone who drives their turbocharged vehicle hard should have one. Perhaps that's why the Spec. C comes with an oil cooler from the factory. This oil cooler is track tested on a race winning vehicle and data logs show that it works. In comparison to competitors' oil coolers, the Gruppe-S Oil Cooler features an extremely high quality European core manufactured by a world famous brand and a thermostat of similar quality.
Key Features:
*High quality European core (240mm x 120mm x 45mm), not some Taiwanese knock off core.
*Thermostat operated Oil Cooler to avoid cooling cold oil upon startup.
*Aerospace fittings / stainless steel lines, professionally assembled and tested to 1000psi.
*Light weight mounting brackets.
In the words of USTCC race car driver Brian Lock, “this oil cooler rocks. After installing this setup we never had a problem with oil temperature again. Even at PIR where it was 115 and it was so hot inside the car I thought my legs were on fire, it was golden. Brian Lock thinks that this oil cooler is the ****, Brian Lock thinks you should buy it.”
Gruppe-S Intercooler Hose Kit for 02+ WRX $99 shipped !
The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing flow and increasing the airflow diameter, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs.
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Old May 9, 2006 | 12:54 PM
gruppe-s's Avatar
Mounts and Acessories:
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped
These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts.
STi Group N Engine Mounts - 02+ WRX / 04+ STi - $95 Shipped
STi Group N Pitch Stop Mounts - 02+ WRX / 04+ STi - $45 Shipped
The STI "Group-N" Engine Mounts and Pitch Stop mounts are designed to reduce excessive motion of your motor during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.
STi Group N Engine / Pitch Stop Mount Combo - 02+ WRX / 04+ STi - $130 Shipped
Cusco Radiator Shroud - 02+ WRX / 04+ STI - $99 Shipped!
Built Shortblocks and Motors:
Gruppe-S Stage 1 USDM STi Longblock - $3999 + Shipping (built to order)
We have one blown STi motor that we will be rebuilding into one of our stage 1 longblocks (balanced, forged Wiseco pistons, coated race bearings, etc.). This longblock will be capable of holding 535 crank HP consistantly and will drop into any WRX or STi easily. Build time will be ~3 weeks and a 50% deposit will be required. You will not see this price on a longblock like this again!
*Longblock does not include ancillaries located on top of motor or accessories: no water pump, AC condenser, power steering pump, intake manifold, wiring harness, turbo, intercooler, etc.
-Gruppe-S / Wiseco Forged Pistons (custom spec)
-Gruppe-S Coated High Performance Rod & Crankshaft bearings
-Forged STi connecting Rods
-Forged STi crank shaft
-ARP Headstuds
-Cometic Head Gaskets (on long-block option)
-Professionally balanced rotating assembly (recommended 7500 RPM redline)
-Rehoned cylinder walls
-Capable of up to 535HP Operation
-~3 week build time, 50% deposit required
*Picture represents product and is not actual product. Actual product is longblock, not motor.
Gruppe-S 2.2L Stroker Kit for EJ20T - $1399 + Shipped
These are all the parts needed to build a 2.0L turbocharged motor (WRX or JDM STi) into a serious power making 2.2L stroker motor. This motor should be capable of holding 550 crank HP while revving to 7500 RPM if properly balanced. It includes the following:
-Custom spec Wiseco forged stroker pistons
-STi forged connecting rods and bolts
-STi forged crank shaft
-Gruppe-S coated racing bearings
Gruppe-S 2.5L Stage 1 Shortblock - $2599 + shipping
Our Stage 1 shortblock replaces the components we feel are most likely to fail in the USDM STi shortblock. This is essentially a bulletproof USDM STi shortblock and will compliment a GT30R, SZ55, FP Red , FP Green, or TD06-20G sized turbo nicely on 100 octane. WRX owners can benefit from this shortblock also since their heads will bolt right onto it; however, combining their heads with something like the Helix cams and valvetrain and this shortblock would yield something with peak power output similar to the USDM STi. In comparison to other companies' Stage 1 shortblocks, our adds coated race bearings and balancing to within 1 gram (JDM STi motors are balanced to within 7 grams).
Features:
-STi Forged Connecting Rods
-STi Forged Crankshaft
-ARP Headstuds (on long-block option)
-Capable of up to 535+ CHP Operation
-Final Displacement 2.48L
-Compression ~8.5 : 1
*Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order.
Gruppe-S Stage 2+ 2.5L Shortblock - $3999 + shipping
Our Stage 2+ shortblock is built for big numbers. This block is capable of over 625 CHP and 7800 RPM. It will max out a GT35R .82 and anything smaller than that. In comparison to the Stage 1, it adds a nitrated, lightened, and magnafluxed forged STi crankshaft and forged steel Pauter connecting rods.
Features:
-Coated High Performance Rod & Crankshaft bearings
-Reworked high RPM Forged STi Crankshaft
-Forged Pauter Connecting Rods
-Gruppe-S Stage Two camshafts (AVCS available) (on long-block option)
-Gruppe-S Stage Two Valve Train (on long-block option)
-Professionally balanced and assembled (recommended 7800 RPM redline)
-Capable of up to 625+ CHP Operation
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Old May 9, 2006 | 12:57 PM
gruppe-s's Avatar
Catbacks:
Helix Full Ti JDM type Exhaust for WRX / STI - $849 Shipped
Helix has just released a limited edition full titanium exhaust. However, unlike the JIC and Greddy Exhausts, this exhaust is not made from rolled titanium tube; it's made from true tubular titanium (like the Amuse).
Again, this is a true JDM spec exhaust system. It is not Chinese made titanium, or constructed by rolling titanium into a tube and then welding it (basically non-seamless tube), The Helix unit uses full JDM aerospace grade titanium that is one piece extruded titanium pipe.
- Super lightweight 11.5 LBS
- JDM Spec SEAMLESS Mandrel Bent Piping
- Available in both blue scorched tip and normal
- Robotic TIG Welding
- Includes gaskets
*Scorched tip version shown.
HKS Hiper for WRX / STI - $529 shipped
-75mm piping
-Full stainless steel, comes with all gaskets and hardware
HKS Carbon Ti for WRX / STI - $719 shipped
-75mm piping
-Full stainless steel with carbon canister and titanium tip, comes with all gaskets and hardware
Greddy Evo2 for WRX / STI - $579 shipped
-CARB certified, under 95 db
-80mm piping
Greddy SP2 for WRX / STI - $539 shipped
-80mm piping
Perrin:
Perrin Front Mount IC for WRX / STI - $1099 shipped
-Rated for 500-800 HP
-Low pressure drop across core, efficient core.
-Comes w/ new bumper beam
Perrin Signiture Series FMIC for WRX / STI - $1175 shipped
-Comes w/ wrinkle red piping
Perrin Big MAF for WRX / STI / FXT - $209 shipped
-Allows more air to travel through the MAF without maxing it
-Highly recommeded for 20G / Green and larger sized turbos
-Requires tuning
Perrin Turbo Inlet Hose for WRX / STI / FXT - $209 shipped
-Smooths airflow into turbo
Perrin Downpipe for WRX / STI / FXT - $319 shipped
-304 Stainless, 75mm piping
-Divorced wastegate design
MORE PERRIN HERE: http://www.gruppe-s.com/subaru.htm
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Old May 9, 2006 | 01:43 PM
gruppe-s's Avatar
We've got some new T-shirts that I happen to think are pretty fresh. Notice how the front of the shirt has the cam-covers on it but the back doesn't. We're so clever!
Gruppe-S T-Shirt - $19 Shipped!!!
-Black - M, L, XL, XXL
-White - L only
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
gruppe-s
Engine and Drivetrain
Aug 11, 2006 05:34 PM
gruppe-s
Jun 23, 2006 12:26 PM
gruppe-s
Jun 22, 2006 12:53 PM
