LIC Motorsports Radiator/Oil Cooler Combos
Old Sep 29, 2011 | 09:42 AM
LICmotorsports's Avatar
Former Sponsor
From: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
After years of testing/usage and 2 distinct variations in kits, LIC Motorsports is proud to announce their custom Radiator/Oil Cooler combo packages. These kits are made from the finest materials and with the pros of the likes of NASCAR and IRL. With 2 kits available its been made easy to choose which one suits your needs. Each kit comes with laser etched LICmotorsports on the top of the radiator, all fittings suplied are AN, and both variations are -10 AN male fittings (for the oil cooler).
The first kit also referred to as "v1 Street" is designed for the daily driver who likes to hit the track as a weekend warrior. The radiatior also has a filler neck on the radiator for easy purging of the system and this kit also accomodates the use of stock fans (with minor modifications) or full race fan setup. This kit has been tested on the LIC Motorsports race car and can withstand the rigors of a 550whp Subaru but is intended for moderate to light track use only.
The second kit also referred to as "v2 Race" is designed for race environments only, can be used in conjunction with a higher pressurized cooling system and will hold more fluid capacity than any other aftermarket off the shelf radiator kit on the market currently. This kit is currently in use on the LIC Motorsports race car and has with stood in excess of 110+ degree heat in the Nevada desert.
Lots ask why the need for two variations, well its simple, the "v2 Race" model runs so cool its not appropriate for daily driven cars. All cars need to come up to temperature and this kit is designed to keep temps much cooler, even while in use with a stock thermostat (which the LIC Motorsports race car uses as well). While testing this kit in the Nevada desert with 110+ degree heat, the temps were in check at 190f water and 210f oil. As the car gets pushed for many laps and hard sweepers, the most the system ever saw was 207f water (fans kick on at 205f) and 232f oil.
The system works flawlessly and it's a major reason more and more Time Attack teams are gravitating towards this kit. Its compact with direct drop in fitment (custom top radiator support brackets will need to be made to work with the v2 kit), can be purchased in many tiers and has the ability to fit anyone's needs.
Available in 2 Configurations
- Cores Only (kit includes: Radiator, and Oil Cooler ONLY)
- w/ Fans (kit includes: Radiator, Oil Cooler, SPAL Race Fans, Fan Brackets)
LIC Motorsports v1 "Street" Kit
Front view
Back view (shown with Race Fans and Brackets)
As you can see fits with stock mounting tabs
LIC Motorsports v2 "Race" Kit
Front View
Back view (with race fans installed)
Installed view (requires custom mounting brackets)
Fitment: 02-07 WRX/STi
These kits are located in our online store: LIC Motorsports Radiator/Oil Cooler Combo (02-07 WRX/STi) - Buy online at LICmotorsports.com!
__________________________________________________ __________________________________________________ __________________________________________________ __________________________
NOW AVAILABLE for 2008+ WRX/STi
After years of testing/usage and 2 distinct variations in kits, LIC Motorsports is proud to announce their custom Radiator/Oil Cooler combo packages. These kits are made from the finest materials and with the pros of the likes of NASCAR and IRL. With 2 kits available its been made easy to choose which one suits your needs. Each kit comes with laser etched LICmotorsports on the top of the radiator, all fittings suplied are AN, and both variations are -10 AN male fittings (for the oil cooler). In addition the OEM radiator on the 08+ WRX/STi are far inferior to the older model cars, they are literally half the size they once were...If you track your new generation Subaru, you need an upgrade to the cooling system.
The first kit also referred to as "v1 Street" is designed for the daily driver who likes to hit the track as a weekend warrior. The radiatior also has a filler neck on the radiator for easy purging of the system, kit also includes coolant expansion tank, and race fans.
The second kit (Pending Release) also referred to as "v2 Race" is designed for race environments only, can be used in conjunction with a higher pressurized cooling system; it includes coolant expansion tank, and race fans. This kit does not come with a filler neck and will be harder to purge the system.
Lots ask why the need for two variations, well its simple, the "v2 Race" model is designed to run the system at a higher pressure than stock, which isn't appropriate for daily driven cars.
Available in 1 Configuration Only
- v1 Kit includes: Radiator, Oil Cooler, SPAL Race Fans, Fan Brackets, Coolant Expansion Tank
Fitment: 08+ WRX/STi
These kits are located in our online store: LIC Motorsports Radiator/Oil Cooler Combo (08+ WRX/STi WRX/STi) - Buy online at LICmotorsports.com!
-Noah
Old Sep 29, 2011 | 09:49 AM
Those are sexy! I know i saw one on DBs new shop car too
johndabrit's Avatar
Da Brit.
I'd love to run the street version on my car. It looks well made and oem fitment makes it a really easy install. When my bank account grows up I'll come knocking
Old Sep 29, 2011 | 09:50 AM
Former Sponsor
yeah lots of race teams with subies are running our kits now. Just shipped one off to a team in Germany as well
sounds good!
-Noah
Old Sep 29, 2011 | 10:13 AM
Former Sponsor
We get asked often: Is the kit truly a 2 piece design?
Answer: Yes its a two piece design all put together in one package to fit in stock location. The bolts detach and either the radiator or oil cooler can be serviced separately if needed.
-Noah
Old Sep 29, 2011 | 10:52 AM
k-dogg39's Avatar
Lil' Slugger
Car Info: 05 WRB STi Wagon/00 BRP GC Sedan
Wow! Nice job, looks great.
Old Sep 29, 2011 | 05:47 PM
Former Sponsor
thanks!
we've had these readily available for sometime...
-Noah
Old Apr 11, 2012 | 02:22 PM
Former Sponsor
Updated first post. 2008+ WRX/STi kits now available.
-Noah
Old Apr 11, 2012 | 02:37 PM
flat489's Avatar
Car Info: '11 STI
so sick, gonna go broke, but this is now on my to buy list haha
Old Apr 11, 2012 | 04:01 PM
Former Sponsor
thanks!
-Noah
Old Apr 13, 2012 | 03:54 PM
Former Sponsor
added a few installed/test fitted pics to post #1
-Noah
Island Style
Hawaii Classifieds
May 12, 2010 05:41 PM
depdivr
Sep 29, 2005 10:52 PM
Get LIC'd...?
Mar 23, 2004 08:16 PM
Get LIC'd...?
Mar 9, 2004 12:48 PM
