IMPREZA GDB STi Stock replacement bolt-on F1 turbo
Old Mar 7, 2007 | 12:44 PM
FIA-WRX's Avatar
Car Info: 05 sti
Fiaimpreza.com is a proud to announce PE as our new family member. We are an uathorized installation , Distribution and Retail facility. All purchases made through us carry full PE USA warranty and tech support.
"PE1825F"is the quickest response turbo in the world.
As opposed to the single-exhaust entry turbine housing on the previous GDB model, the newer GDB STi has the twin-entry, designed for smoother exhaust gas entry to the turbine housing without having exhaust interference from the left & right banks. Torque and response at low to mid range are drastically improved by utilizing thetwin entry and as allways the PWR turbo's feature the ball bearings. The compressor wheel of big 70mm easily supports monstrous quick spooling 400++ps of power all the way to the high RPM range. The bolt on installation needs no additional work
.Boost range 1.3 ~ 1.4 kg
A/R : 25 (400+ps application)
Compressor wheel diameter: 70mm
Turbine housing : twin-entry
Center section : ball bearings
PE1825F for Impreza
GDB STi $3200
I-club price 2700.00 shipped.
PE1825F for Impreza
GDB STi
w/Rebuildable(separative)
Actuator $3300. Sseparative Actuator is an unique part developped by PWR to be able to replace different stiffness of actuator springs for higher boost applications.
I club price 2775.00 shipped.
Get any of the kits above installed for 199.00 when purchased from us.
Old Mar 8, 2007 | 11:58 AM
FIA-WRX's Avatar
Car Info: 05 sti
all pms replied
nation
Mar 18, 2011 02:13 PM
Crimedog
Oct 27, 2004 05:42 PM
James Munet
Oct 9, 2004 12:40 AM
Dinko81
Dec 30, 2003 04:52 PM
DDMan
Sep 6, 2003 02:13 PM
