Engine Building Services at DBTuned.
Old Aug 17, 2010 | 08:41 AM
  #46
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Actually it make perfect sense as the tighter spec motors were running 30 and 40 weight oils while the looser spec were running the recommended 50 weight.
-- Ed
Old Aug 17, 2010 | 08:44 AM
  #47
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Originally Posted by EQ Tuning
Could you explain why you believe a 10-40 oil would work better on the track than a 5-40?
-- Ed
could you adress this?
Old Aug 17, 2010 | 09:24 AM
  #48
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Call Redline Oil, they'll help you out.
Looser clearance = lower engine oil temp?
Tighter clearance = higher oil temp?
If the engine oil is getting hotter, where is heat coming from?
Old Aug 17, 2010 | 09:40 AM
  #49
ipozestu's Avatar
Car Info: Broken Subarus
Pressure would be dictated by the size of the orifice. I this case the the total sum of the oiled parts. That spec remains constant. The oil viscosity, say 40w for instance, is 40w at operating temperature. This is also a constant. The pump is variable speed and variable pressure. That pressure once again is determined by what it has to push against. Take a garden hose for instance, if you turn the water on and let it flow, you end up with high volume, low pressure. Now cover half of it with your finger, you've increased the pressure in the hose, you've also increased the velocity/pressure of the fluid exiting the hose. This velocity has the potential to do work. In this case the work is floating the journal. Within the rod crank bearing assembly pressure is what floats the journal. Not the oil. Oil is just a fluid. It has similar properties to other fluids. One of which is it's resistance to compression. We all know you cannot compress a fluid, (compress=pressure). This is what enables hydraulics to do work. We supply a pressure to a fluid with the intention of performing work. Oil does a few things, removes heat, lubricates, protects, transfers energy.In this case it transfer energy provided by the pump to the journal. That energy is the oil wedge between the metal parts. If you increase the size of the orifice (remove finger from garden hose) you are removing energy from the fluid reducing it's potential to conduct work. You cannot adjust one with out affecting the other. Every component of a hydraulic system is dependent on the other.
Old Aug 17, 2010 | 09:57 AM
  #50
ipozestu's Avatar
Pressure and temperature are linear. A tighter clearance should yield higher pressure which in turn would yield higher temp. Now this is fluid temp. It's the coolers job to move that heat from the oil. The cooler has it's own efficiency. The delta T between the inlet and the outlet should remain constant.
Old Aug 17, 2010 | 10:09 AM
  #51
ipozestu's Avatar
Double post
Old Aug 17, 2010 | 11:02 AM
  #52
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Did you call them to come up with your recommendation? Do you have any reasoning behind recommending that a 10-40 works better on the track than a 5-40?
Do you realize that the first number (5/10) is the viscosity of the oil when its cold and the second number (40) is the viscosity of the oil at operating temperature? Understanding this, how would a 10-40 oil be more appropriate for track use where you are always at operating temperature? The two oils should act the same at this temperature correct?
-- Ed
Old Aug 17, 2010 | 11:21 AM
  #53
ipozestu's Avatar
-- Ed
The higher the spread between the bottom number and the top number the more VI improvers are relied on for maintaining the viscosity. Better to keep the numbers closer.
Old Aug 17, 2010 | 11:22 AM
  #54
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Very good explanation. The one thing to remember is that pressure and flow have to do with resistance (the size of orifice) as well as the viscosity of the fluid. With a larger orifice (looser clearance), you can maintain the same oil pressure by increasing the viscosity of the fluid (oil in this case).
The other thing to remember is that pressure, is in essence, resistance to flow. So a higher pressure means that less fluid is actually flowing past the orifice. In terms of engine bearings, the oil is providing pressure to float the journal, and its also cooling the journal and bearing surface as it flows through. As you increase pressure, you inhibit the overall flow which also inhibits cooling.
The trick is to find the correct combination of pressure and flow to maintain enough pressure to float the journal while still maintaining enough flow to allow for proper cooling. This combination is very application specific and the clearance spec and oil viscosity chosen both play major roles.
-- Ed
Old Aug 17, 2010 | 11:30 AM
  #55
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Thank you. That's the only potentially logical explanation. The viscosity modifiers in older oils were known to break down more easily and therefore people recommended running oils with smaller viscosity variants. In most modern synthetics, however, this is not nearly as much of an issue. This is why you see 0w-40 oils used in many European cars now.
-- Ed
Old Aug 17, 2010 | 12:16 PM
  #56
iClub Silver Vendor
Ed:
You asked for a recommendation and a I provided one; either weight oil in the brands that we use work just fine.
With regards to your spec on your motors, and with the data that you have gathered, can you please provide us with this information?
Originally Posted by Me
Looser clearance = higher/lower engine oil temp?
Tighter clearance = higher/lower engine oil temp?
There are several local shops/customers campaigning race cars that would take exception to this statement.
FWIW:
The BMW M series engines, with a bearing clearance of .0007in. requires 10-60 oil.
Old Aug 17, 2010 | 12:37 PM
  #57
ipozestu's Avatar
0w oil are being used due to fuel economy ratings and poor care. People are stupid. They think they can get into a car and turn the key and drive away. A 0w oil would be a very poor choice for any sort of performance application..
The question isn't about the oil weight as both cases are using 40w oil.
Pressure is not the resistance of flow. Pressure is a force applied to a specific area. So psi is just that, 1 psi= 1lb distributed throughout and area of one square inch. SO in this case if two said motors, the only variation is the size of the bearing clearance (more specific area) would result in less force per square inch.
Old Aug 27, 2010 | 08:26 PM
  #58
iClub Silver Vendor
Kickin it old school...building an EJ22 Outback Engine.
Old Aug 31, 2010 | 05:24 PM
  #59
wombatsauce's Avatar
Car Info: 2018 Golf R Variant
Subscribed for the wealth of information and the pretty pictures!!
Old Aug 31, 2010 | 05:35 PM
  #60
newyorkreload's Avatar
Car Info: Bugeyed Autowagon
Ever had any request for EA-81 builds?
