Aps Headers And Inlet’s In Stock!!!!
Old Mar 10, 2006 | 05:03 PM
RallySportDirect's Avatar
Former Sponsor
Car Info: GC,GF,GD,GR,GH
After a long trip from over seas the APS headers are finally here!!!! Get them before their gone!!!
Only 995.00 SHIPPED
GET YOUR HEADER HERE
APS has configured a header that dose not lose 30 ft. lbs. of torque to gain 10 hp above 6000 rpm in fact it gains 30 ft. Lbs. at 3000 rpm and gains an additional 30 hp at 6000 rpm! Finally a header that works with out having to sacrifice bottom end power for top end power!
Also in stock are the APS Turbo inlet hose. This is the only metal hose on the market and comes with everything you need plus 2 different couplers to fit all turbos.
ONLY 275.00 SHIPPED
GET YOUR INLET HERE!!!
The APS Turbo inlet pipe is superior in that it is an stainless steel peice, not silicon. The stainless construction means that the pipe will not collapse under high boost. Also being steel, it allows for a much larger inner diameter for maximum airflow utilizing the thin-walled stainless steel.
Each APS Turbocharger Inlet Pipe is delivered with two entry pipe to turbocharger silicon coupling hoses.
One hose to suit the stock turbocharger and large 3" internal diameter hose matched to high performance turbochargers with a 3" inlet.
THESE WILL SELL OUT QUICK. GET THEM WHILE THEY LAST!!!
INLETS OFFICALY SOLD OUT, FEW HEADERS LEFT
-Jason
Rallysport Direct.
www.rallysportdirect.com
801.619.1779
Old Mar 10, 2006 | 10:40 PM
tmeultraman's Avatar
nvm...
Old Mar 12, 2006 | 02:10 PM
luktang's Avatar
Car Info: 04 PSM WRX
is the header for STi only? or fits a wrx? Thx.
Old Mar 13, 2006 | 09:53 AM
Former Sponsor
The headers are for 05+ sti. They can fit the wrx if you get an sti oil pan and assoicated bits that go along with it.
-Jason
Old Mar 14, 2006 | 12:06 PM
Former Sponsor
Bump
-Jason
Old Mar 15, 2006 | 11:39 AM
Former Sponsor
aps inlets gone
Bump
-Jason
Old Mar 16, 2006 | 11:58 AM
Former Sponsor
BUMPERS
-Jason
Old Mar 17, 2006 | 03:08 PM
Former Sponsor
bump
-Jason
Old Mar 20, 2006 | 04:50 PM
Former Sponsor
bump
-Jason
Old Mar 21, 2006 | 03:52 PM
Former Sponsor
Bump
-Jason
Old Mar 22, 2006 | 03:13 PM
Former Sponsor
bump
-Jason
Old Mar 24, 2006 | 01:38 PM
Former Sponsor
bump
-Jason
Old Mar 24, 2006 | 03:23 PM
EndlessWaltz RS's Avatar
Car Info: 00 BRP RS LIC'd 01 EJ207 + non DCCD 6 Speed
Any info on why the APS header is so much more effective than say Cusco, GT Spec, Helix, GReddy, or any of the others? Also, any dyno graphs?
Old Mar 24, 2006 | 09:54 PM
BLuStI04's Avatar
any headers for the 04 sti?? n how much ship to hawaii (96797
Old Mar 27, 2006 | 01:37 PM
Former Sponsor
its mostly due to design. all of the above mentioned headders use a 4-1 design while the aps uses a 4-2-1 design. smoother flow with less back pressure gives it an advantage over the other designs.
as for stock we have officaly sold out of the headers, next shipment in april.
-Jason
