Tranny problems on 04 WRX?
I'm looking into the '04 WRX if I can get one cheap enough (invoice or close to it) with the cheap financing. BUT... I've read a number of threads on this site that indicate lots of transmission problems on the 5sp, and lots of warranty denials.
I'm coming over from a supercharged '98 Z28 (550 hp) and wanted a car that's a bit more practical in bad weather... but I don't want to worry about blowing up transmissions or dealing with warranty issues.
Thanks!
Rob
Thanks!
Rob
I believe most of the warrenteed bad tranny experiences are limited to the 02 WRX's... Other than that, I'd say most other tranny bad experiences are due to bad driving since the car doesn't take to hard launches very well.
Car Info: want a WRX
the tranny is fine as long as you dont pop the clutch...slip it instead ...in other words put wear on ur clutch...not ur tranny...of course you'll run through clutches fast...but thats only if you launch a lot...now of course skill, driving style and mods all factor in...if you have a stage 2+, you have enough low end power to not need an 'awd launch' to win
grex767
May 27, 2006 10:37 AM
roflrofl
Sep 6, 2005 11:59 AM
