RPM goes up while in gear, vehicle speed remains slow (was: Is This What It Is?)
Old Nov 12, 2006 | 09:05 AM
Lazyboy's Avatar
Car Info: 2004 wrx impreza
Is This What It Is?
so i was going up the parking lot to the second floor to park my car in an indoor parking lot when my rpms started shooting up but i was going like 5 miles per hour. does this mean the clutch is slipping? i have a 2004 wrx with vf 39 with modz like exhaust up-pipe dp etc.
Old Nov 17, 2006 | 06:13 AM
Wingless Wonder's Avatar
Fixed thread title. Sometimes it helps to use an appropriate title if you want a reply since not all members bother reading every single post.
If the revs went up at 5 miles per hour and your foot was not depressing the clutch pedal at all, then yes, your clutch is slipping or else it is not fully engaging for some reason. A worn clutch will also slip more noticeably in higher (numerical) gears if you step on the throttle.
Old Nov 17, 2006 | 06:37 AM
Lazyboy's Avatar
thank you wingless wonder. i'll keep that in mind. thanks again
Flame30689
Sep 22, 2008 10:16 AM
2point5AWD
Jul 1, 2006 07:19 PM
c4ninja
Jan 8, 2006 10:14 PM
adnan
Jun 14, 2005 11:58 AM
