Problem with Kartboy shifter bushings...
Old Aug 16, 2004 | 09:56 PM
rustokman's Avatar
Car Info: Black 03 WRX
So I decided to finally install the kartboy shifter bushings today, I managed to do so without unscrewing the crossmember under the tranny. I was all done and had a smile on my face till I got in the car and went for a drive. 1st, 2nd, and 4th have no problems but I have a really hard time getting it into 3rd gear and 5th is almost impossible to find. I needed to shift to third but by the time I found it, I had to downshift back down to second to speed up. NOT GOOD!
If anyone has any advice for me please let me know.
Thanks in advance.
Old Aug 16, 2004 | 10:50 PM
BrianH's Avatar
Car Info: NONE
you put that metal plate on incorrectly.
Old Aug 16, 2004 | 11:36 PM
rustokman's Avatar
It can only go on one way...
Old Aug 16, 2004 | 11:51 PM
BrianH's Avatar
Car Info: NONE
well then I broke it and managed to put it on correctly and I had the same symptoms as you, a tech looked at it flipped it over called me an idiot and put me on my way. I've yet to replicate those issues since.
Old Aug 17, 2004 | 12:10 AM
rustokman's Avatar
haha...I thought I put it in the way I popped it out but I may be mistaken. I will flip the plate over tomorow.
BTW, was the left side bushing harder than hell to get in, I tried forcing it with what little room I had for about 15 minutes till i finaly just forced it on by tightening the bolt...
Old Sep 6, 2012 | 09:32 AM
boxer4turbo2004's Avatar
Car Info: 04 Subaru WRXSTi
they say to press it in with a bench vise..or you may rip it..
Old Sep 6, 2012 | 09:35 AM
what plate are you guys talking about? Im doing this install today..
RallySportDirect
Vendor Group Buys/Specials
Apr 7, 2004 02:04 PM
Speed Element
Dec 2, 2003 10:32 AM
The Mirror
Aug 26, 2003 09:04 AM
GR8-WRX
Jul 11, 2003 11:09 AM
betawrx
Dec 31, 2002 10:26 AM
