Please Help!! Check Engine light...
Old Apr 25, 2009 | 09:02 PM
blackbullet03's Avatar
Car Info: Subaru WRX Impreza
Question Please Help!! Check Engine light...
So my car was perfectly fine until this morning i was going to work, and my check engine light went off, so I kind of ignored it for the time being because i was at work, but on my way home, it began acting really funny. As i'm driving my car, gassing it, it would just basically loose throttle. As if my car was low on gas and was dieing, even with my foot on the gas the car wasn't moving forward, just slowing down as if my car was in neutral. it wasn't even reving up. Basically it was acting as if your car is about to die because you have no gas...but i had a full tank so that's not the problem. Does anyone know what it might be?!?! I have no idea, i'm thinking maybe the alternator???
Old Apr 27, 2009 | 02:48 PM
D_Gen_X's Avatar
Car Info: 2005 Subaru Sti
Not an expert or anything but I am pretty sure it isn't the alternator. Possibly check into the fuel filter or maybe even the fuel pump is bad.
Old Apr 27, 2009 | 02:53 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
My god says im OK but im pretty sure YOUE EFFED! BAHAHAHAHAHAHAHAH!!!! j/k
No Idea with no AP cant see code. I would just bring it to the shop......
Old Apr 27, 2009 | 03:55 PM
sticruisin06's Avatar
Car Info: 06 wrb sti
ECU problem maybe? try resetting it. take the black part of the battery and hold the brakes then put it back. hope that helps
Old Apr 27, 2009 | 09:26 PM
Subadubaru's Avatar
Car Info: 03/05/06 WRX with some STI parts :- P
my best thought would be a clogged fuel filter or pump... maybe clogged injectors?
Old Apr 28, 2009 | 03:52 AM
i took it to a near by mechanic and had him read the code. he told me it's the exhaust sensor. i guess the wires are short and have gone bad so i gotta replace it. what the sensor does is it determines how much air and fuel go through the engine, kinda makes sense because the car did seem like as if it was dieing due to no gas in the tank.
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
BrianA
May 10, 2003 03:31 PM
The Works
Dec 30, 2002 08:53 PM
