Need a second opinion on my flywheel problem
Old Oct 11, 2010 | 06:52 PM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
My car has been experiencing tons of shuttering when i engage the clutch, whether it is from stop to go or downshifting. I took the car to a mechanic and he said it is because my flywheel. He quoted me around 450 for labor excluding parts. I was wondering what would be the effect if I swapped in a lightweight flywheel? Or should I just stick with a stock flywheel?
Specs: Stock 03 WRX
I've review some threads about the horrible 03 transmission and that i shouldn't change out of my stock clutch. Mainly I'm trying to spend as little as possible but moving forward in terms of modding (I have the intent to increase my HP in the near future). I don't want to spend the money and later on regret it because it wasn't a good investment.
Opinions?
Old Oct 11, 2010 | 09:04 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
How many miles on the transmission?
Old Oct 14, 2010 | 04:43 PM
WRX>Civic's Avatar
I only got 74K
Old Oct 15, 2010 | 09:32 PM
iClub Silver Vendor
Stick to the OEM clutch kit. Make sure to either use a new flywheel or have yours resurfaced.
Old Oct 17, 2010 | 05:15 PM
WRX>Civic's Avatar
Ic. Do you think i need chg the entire Clutch plus the flywheel? or is my problem only coming from the warped flywheel?
Old Oct 17, 2010 | 05:51 PM
iClub Silver Vendor
If you're still on the original clutch, replace the entire assembly.
First see if the flywheel can be resurfaced.
Old Oct 22, 2010 | 12:57 PM
WRX>Civic's Avatar
Oh ic, Thanks for the info! I'll run it by my mechanic. If not I might have to give you a call.
Old Dec 29, 2010 | 03:47 PM
lucassubaru's Avatar
hey did you get your flywheel don im having the same problem but i have two warped spots exactly on opposites sides from each other
4080wrx
May 8, 2010 03:37 AM
xicema17x
Mar 16, 2009 01:45 AM
RallyWagon
May 11, 2006 07:29 PM
tarak
May 19, 2004 02:26 PM
phoenixm///
Jan 8, 2003 08:15 PM
Top
