HELP!: AT Oil Temp
Old Jun 29, 2004 | 09:38 AM
Heavy Dan's Avatar
Car Info: '02 WRX, Aspen White, Stage 1 Cobb
HELP!: AT Oil Temp
I changed my K&N air filter last night.... and peeled my car out of the driveway... about 30 yards down the road the "AT Oil Temp" light came on....
Am i in big trouble? what happened?
Old Jun 29, 2004 | 04:46 PM
RussB's Avatar
Car Info: $200,000 sports car
what kind of car?
Old Jun 29, 2004 | 05:33 PM
Heavy Dan's Avatar
2002 wrx AT... (sometimes i forgot that non wrx drivers are on this site)...
Old Jun 29, 2004 | 07:21 PM
RussB's Avatar
i have an 03 auto wrx. how do you peel out in an automatic?
real answer, check the transmission fluid level, but follow the instructions in the manual for checking it while cold. don't try it after the vehicles been driven within the last couple hours or you'll burn yourself on the bottom of the IC. if everything's fine, it might have been a fluke, or peeling out might have heated up the fluid a bit.
Old Jun 30, 2004 | 02:05 AM
Littleboyblue's Avatar
How did you peel out? Anyways, like the above post says, check the transmission and oil. If its fine and the oil light went off, I wouldn't worry about it too much.
Old Jun 30, 2004 | 07:39 AM
Slack's Avatar
Car Info: '02
The Oil Temp light coming on can be any number of possible problems. You can take it to the dealer to have them pull the trouble code out of the TCU, there is also a way you can count the blinks of teh AT light, not sure of that procedure though.
Old Jun 30, 2004 | 10:06 AM
Heavy Dan's Avatar
Maybe it has to do with the fact that my air filter was still very moist from the K&N recharge?
Old Jun 30, 2004 | 12:39 PM
I doubt it.
Old Jun 30, 2004 | 02:04 PM
Heavy Dan's Avatar
Originally Posted by Littleboyblue
I doubt it.
I doubt it as well... but I was thinking that the excess oil could cause lesser flow and perhaps more stress on the AT. It's a huge stretch... but, my car is alright for now.
Old Jun 30, 2004 | 03:38 PM
Its probably just a fluke. If you're really worried, take it in to get check out.
Old Oct 9, 2004 | 08:07 PM
Swordafish's Avatar
I have a 2000 Legacy. The AT Oil Temp light went on steady, once before and I had it checked out. They changed the filter and checked the trans and said it was fine. This was not a Subaru shop but the light went off and I have had no problems till today. The light went on again but this time it was blinking once per second.
Should I bring it into a dealership or a trans shop like AAMCO. I am up for ops here.
Old Oct 11, 2004 | 09:53 AM
Swordafish's Avatar
AT Oil Temp Light
Originally Posted by OneOBS
AAMCO has trouble with Chevys. I sure wouldn't take them a Subaru.
"You gotta what?"
"Is that one a them thar foreign cars?"
LOL.
I guess I will have to bring it into a dealership. Was hoping to save some $$$. I hope its just a chip problem.
Old Oct 27, 2004 | 03:12 AM
Group B's Avatar
Dahveed aka Robin Hood
no. no man. naah!
If there was THAT MUCH oil in your air filter, it would hydro-lock (i.e. break) your motor, before it would stress your tranny.
like that Subiegal person who rallies cars into lakes?
when the water (or in this case oil) enters your intake, and your piston tries to compress it in the cylinder??
BOOOOM!!!! (gasses compress, not liquids)
Other than that, even a horribly dirty air filter is going to make the motor struggle to breathe, not make the tranny work harder.
Trannys work harder when you drive uphill, shift the gears manually a lot, do neutral-drops, etc.
Island Style
May 26, 2006 08:59 AM
gordy
Oct 27, 2004 03:03 PM
DigitalRacer
Nov 4, 2003 05:12 PM
bambams247
Aug 21, 2003 08:34 AM
turbo_j
Mar 16, 2003 02:49 PM
