help! help me find a clutch
Old Dec 17, 2008 | 08:36 AM
garrlex's Avatar
Car Info: 2004 Subaru WRX
Question help! help me find a clutch
I just bought an 04 WRX and it needs a new clutch... wasnt beat up just has a 110,000 miles and the guy didnt know how to drive...
I was going to go with the ACT Street Disk setup but if anyone has any recommendations I would be stoked.
Have to drive it everyday and be able to have fun with it in the canyons on the weekends
Old Jan 2, 2009 | 01:51 AM
not12listen's Avatar
Car Info: 06 WRX Wagon
i love my Spec Stage 2. i have an ACT Stage 1 in my 1986 Mr2.
the Spec is a bit more 'snappy' with the engagement, but you'll get used to it really quickly and you'll be able to drive it like an OEM clutch.
when canyon time comes along, the snappy engagement will be something you're going to love. it just GRABS and GOES.
the ACT was more 'forgiving' during initial engagement, but the pedal was 3 times stiffer than stock, whereas the Spec is LIGHTER than stock on pedal stiffness.
my vote is for a Spec clutch - and have a shop install it.
you might also want to have your flywheel resurfaced ($40 task).
Old Jan 24, 2009 | 08:51 PM
thejoeofo's Avatar
Car Info: 02 WRX Sport Wagon
clutch
What amount of difference would it make to get a lighter flywheel? I know it would make a lower inertia and what not but is it a notice-able upgrade? As far as actual clutch I've heard if you get "too good" of an upgraded clutch you can hurt your gears..... So where is the line between a factory clutch and stage 2, 3, 4......?
stg2lgcy00
Oct 1, 2012 11:04 PM
Impretzle
Oct 24, 2007 10:26 PM
WorldONE
Engine and Drivetrain
Jan 29, 2007 05:54 PM
yellow5
Jan 3, 2003 02:34 AM
