gear box oil
I am planning to use 2 quarts of neosynthetic and two quarts of GM synchromesh. I am using mobil synthetisc right now and I can't say that I like it too much. It is too slippery for the synchros to wrok properly so I end up having to be extra careful.
If anyone has any suggestions about my mix let me know.
Car Info: 2002 White WRX Wagon (WWW)
I run Royal Purple Max Gear 75W90 in both the tranny and rear diff. The tranny is 3.7 QTS and the rear end is .8 QTS.
http://mikeegan.stormpages.com/GearOil.html
What does everyone thikn of Tranny oil cocktails? Should I try it, or should I just stick with what works? I have this feeling that using two different oils might make them separate and the whole mix won't flow well through the tranny. I am thinking of just using GM synchromesh and leting it be. Unless someone has some other advice for me...
fd777
Jun 12, 2010 09:05 PM
