gear box oil
Old Feb 9, 2004 | 08:06 PM
rustokman's Avatar
Car Info: Black 03 WRX
I am planning to use 2 quarts of neosynthetic and two quarts of GM synchromesh. I am using mobil synthetisc right now and I can't say that I like it too much. It is too slippery for the synchros to wrok properly so I end up having to be extra careful.
If anyone has any suggestions about my mix let me know.
Old Feb 10, 2004 | 12:54 AM
KmanRuffian's Avatar
Car Info: 2002 White WRX Wagon (WWW)
Let us know how that mix works out ok? Thanks in advance.
Old Feb 10, 2004 | 07:34 AM
Egan's Avatar
I run Royal Purple Max Gear 75W90 in both the tranny and rear diff. The tranny is 3.7 QTS and the rear end is .8 QTS.
http://mikeegan.stormpages.com/GearOil.html
Old Feb 10, 2004 | 11:45 PM
WuWrx's Avatar
i am running motul gear 300 and love it
Old Feb 13, 2004 | 10:01 AM
brento's Avatar
Car Info: 02 RS
i've been running amsoil for over a year now with no problems.
Old Feb 13, 2004 | 08:02 PM
rustokman's Avatar
What does everyone thikn of Tranny oil cocktails? Should I try it, or should I just stick with what works? I have this feeling that using two different oils might make them separate and the whole mix won't flow well through the tranny. I am thinking of just using GM synchromesh and leting it be. Unless someone has some other advice for me...
huck
Aug 23, 2017 02:18 PM
JourdanWithaU
Aug 29, 2014 03:30 PM
fd777
Jun 12, 2010 09:05 PM
WfknRX
Hawaii Classifieds
Feb 15, 2004 08:32 PM
minisiu
May 17, 2003 09:00 PM
