Drive shaft length difference between 4EAT and MT
Old Dec 6, 2002 | 05:32 PM
Z1 Performance's Avatar
yes it is...auto is shorter
Old Dec 6, 2002 | 05:47 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Now is it confirmed that the AUTO driveshaft is the same length as the 6MT driveshart?
Also, what is the difference in terminology between driveshaft and propeller shaft?
Old Dec 6, 2002 | 07:53 PM
scoobiesnacks's Avatar
driveshaft, Driveline, propeller shaft... They are all the same thing. People like to use different names for different parts. Kinda like an O ring can also be called a seal or a gasket.
Old Dec 16, 2002 | 05:12 PM
bamfwrx's Avatar
Car Info: 02 WRX
I'm pretty sure that the input flange would be the same
you need to change the ring and the pinion gears as a set
boxerfxt
Dec 9, 2009 08:31 AM
oyrocker47@hotm
Feb 1, 2007 01:01 PM
bugeye
Subaru OEM Parts For Sale
Oct 31, 2006 08:05 PM
azn_ryder02
21
Jun 11, 2006 07:44 PM
