Clutch problem? Grinding into 4th, shifting hard.
Old Apr 13, 2003 | 07:41 PM
1WRX2NV's Avatar
Car Info: 02 STi
Re: cLuTcHeeee.....
Originally posted by burmis1
When i'm cruzin fast and i **** into 4th gear it has a little grind then it goes in, Im thinking of getting a new clutch, 30,000 mile and a flywheel.
Does anyone know what that grind is, Clutch?
And what is a good clutch, Stage one to replace it with and a good flywheel?
Thanks Bryanb
I could be wrong...but it could be the syncros. I say this because
I had a car that did this and it was the syncros... ALL 5 times
-freddie
Old Oct 14, 2004 | 09:48 PM
TRAXSTARZ's Avatar
I thought it was my syncros too , but when I took it to the dealer, they said that it was my shift fork and not the syncros. They replaced it under warranty.
Old Oct 15, 2004 | 05:31 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
Despite traxstarz experience it's probably your synchros. Try replacing with a different gear oil and see if that fixes it. My grind went away when I switched to Red Line Heavyweight Shockproof but there are many brands to choose from.
RaginBull
Nov 23, 2006 12:16 AM
blue blurr
Jun 22, 2006 02:53 PM
dunnojack
Jul 19, 2005 02:15 PM
EtchyLives
Dec 3, 2003 04:05 PM
