Can anyone help me with the part # for a '05 STI transmission drain bolt?
Old May 28, 2008 | 08:50 AM
cyber_x's Avatar
Hi,
I recently rounded the the drain plug when changing the transmission fluid on my '05 STI. It's the 14 mm oil pan side bolt as shown here:
http://www.iwsti.com/forums/warranty...rain-plug.html
So now I need to order a new one from the dealer. Does anyone happen to have the part number for this? I want to make sure they don't mess something up and give me the wrong part, which has happened in the past.
P.S.
If you also have the part number for the clutch side 21 mm drain bolt, that would be appreciated as well. I don't actually need a new one right now but figure if it's cheap then I might as well pick one up at the same time just in case. Thanks for your help.
MikeyT
Dec 7, 2011 04:12 PM
Dave Sellers
Mar 2, 2008 07:13 AM
EJ20PWR
Sep 21, 2007 01:55 PM
Dinko81
Dec 30, 2003 04:52 PM
