4.444 Final Drive Ratio Conversion Kit
Old Sep 12, 2003 | 11:07 PM
WRX151's Avatar
Guys, I'd love to get a real gear box set up, but the cost really leads me to other alternatives. I was wondering if anyone is running a 4.444 Final Drive Ratio Conversion Kit in their WRX? If so, any feed back on the conversion from installation to what difference you really feel is greatly appreciated. My primary reason for this mod is to get a little more pick up for SCCA.
Thanks a bunch,
WRX 151
Old Sep 13, 2003 | 07:31 AM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
change the ring and pinion in your tranny and you've got a 4.44. No "conversion kit" needed.
you loose a lot of top end speed, but gain a lot of low end go.
Old Sep 13, 2003 | 11:14 PM
Yes, you can just buy the front and rear ring and pinion sets. As long as that ratio was available for the standard Impreza R160 diff, you can just bolt it in on both ends. It's probably not legal for D stock, ST-S/X or CSP. Make sure before you do the change.
LGT Mark
Feb 15, 2011 08:52 PM
wal.lin
Subaru OEM Parts For Sale
May 10, 2008 01:46 AM
2DAI4
Sep 24, 2005 08:09 PM
WRX151
Sep 12, 2003 11:39 PM
