What other parts EJ20 Conversion?
Old Jul 2, 2004 | 11:45 AM
Subaruski42o's Avatar
Car Info: 98 RS
I have a 94 L awd with no engine or center drive shaft. I have a 5spd and ECU w/wireing from a 99L. Also have the two front axles from the 99L.
I would like to put an EJ20 in it but if I come accross an EJ22t some time i would love to drope that in there.
I am in the process of trying to buy a totaled WRX and i would have even more parts to work with if needed.
This is my first car to build from scratch. What else do i need to get this finished? What are my options because i will have a good collection of parts. Oh yeah the ECU on the WRX is a EcuTek reflashed ECU. So that would be able to be changed to my specs.
Any help would be great.
Old Jul 6, 2004 | 10:20 AM
eastbaysubaru's Avatar
Since it's a '94, you may be better off getting the 2.2T in there and running. Depending on where you live, it's a completely legal swap since 1994 was the last year for the 2.2T. I've got a friend considering this route, so it'll be interesting to see how it goes for you. Wiring up a '02 ej20 to a '94 Impreza(?) is extremely complicated from what I've heard/read. You seem like you don't really have a plan set in stone, so you may want to do a bit more research before jumping in to any of these choices. I think the ej22T is your best bet though because the wiring should be extremely similar.
-Brian
Old Jul 6, 2004 | 12:29 PM
Car Info: 98 RS
Of course i would rather go with the EJ22t. I could not find one with less then 100,000. Plus i could not find one with the complete wiring harness and ECU. I have no emissions test in Rockford, IL so legitness is not an issue.
Old Jul 7, 2004 | 12:02 AM
Most of the time when you find a US WRX swap for sale, it's a complete drivetrain. That's definitely the way to go rather than sticking a strong motor on your puny little transmission.
Old Jul 7, 2004 | 06:08 AM
Car Info: 98 RS
But arent both tranny comparable in strength. The 99L tranny would have lower gear ratios. I was thinking all i would need is a stronger clutch for the NA tranny.
Old Jul 7, 2004 | 12:44 PM
No, the NA transmissions aren't as strong as even the WRX gearbox.
Old Jul 7, 2004 | 07:21 PM
Kostamojen's Avatar
NASIOC Slut
There are quite a few USDM swaps running around on RS/L trannys.
Old Jul 7, 2004 | 10:14 PM
There are also people running around with short ram intakes, AFCs, and altezzas. Doesn't make it the best course of action.
Old Jul 23, 2004 | 11:52 PM
ds baruuuuu's Avatar
Car Info: 5.4RS
bwwwwwaahahahahaha that was funny i say use the wrx trans even if its not stronger it will be cheaper in the long run since you can use the factory wrx clutch and flywheel
Old Jul 24, 2004 | 11:10 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
At ~ $3500-$3900, you can pick up a JDM STi EJ20. That is 250-300 WHEEL hp right out of the boxt (depending on the dyno) Plus, it can be easily done to pass SMOG with few minor tweaks.
With a lightweight GC chassis and that power, you will be giggling for a while.
03SubaWRX
Nov 17, 2005 02:27 PM
03SubaWRX
Subaru OEM Parts For Sale
Nov 16, 2005 10:36 PM
03SubaWRX
Nov 16, 2005 07:57 PM
1fastGC
Dec 17, 2002 10:00 PM
1fastGC
Dec 14, 2002 08:12 PM
