Engine turns but won't start.
Old Dec 10, 2011 | 11:18 AM
Johannelle's Avatar
Car Info: Impreza 1998
My mechanician changed my the 98 Impreza 2.2 for a 2.5. Turns really good when pouring gaz manually. Thank you.
Old Dec 10, 2011 | 11:32 AM
VRT MBasile's Avatar
Could you possibly get someone else to translate your problem? I can't understand the issue from your post.
Old Dec 10, 2011 | 11:39 AM
DerekB707's Avatar
Car Info: 07 rs STi swapped Rotated BW S200SX-56
Engine must haves: compression, fuel, and spark. Which one is missing...
Old Dec 10, 2011 | 01:23 PM
Johannelle's Avatar
Fuel is somehow missing because:
Injectors don't seem to get signal.
Old Dec 10, 2011 | 02:03 PM
DerekB707's Avatar
There is so much information missing here. Did you swap complete motors or just a shortblock. Any ecu modifications? Not really giving people alot to go off here.
Old Dec 10, 2011 | 04:35 PM
Johannelle's Avatar
I'm only driving the car.
I'm trying to help my friend mechanician who is getting discouraged but he thinks it must be only a little detail that doesn't work. He swaped complete motors, cleaned intake, changed gaskets, timing belt of 2.5, injectors of 2.5, flywheel of 2.5, crank sensor also but he checked and same as 2.2.
He installed knock sensor of 2.2 cause the 2.5 had a broken wire. He installed a cam sensor jobber. Kept Ecu of 2.2. Thanks for trying to help.
Old Dec 10, 2011 | 04:38 PM
nic3krnnamja83's Avatar
I am guessing Montreal = French Canadian... English not first language.
Old Dec 10, 2011 | 04:41 PM
Johannelle's Avatar
True, I just don't have a mechanic language.
Old Mar 29, 2012 | 07:48 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
Mechanic Language spells gaz like "gas"
smokeyy89
Mar 23, 2015 03:27 AM
scoob808
Aug 10, 2014 12:45 PM
borderlessworld
Jan 2, 2013 01:14 PM
super-ooh
Feb 18, 2006 04:50 PM
zionsyouth86
Feb 23, 2005 10:25 PM
