93 Impreza L Turbo Won't Start! Help
Hey guys, I wanted to ask if anyone has had this problem with there car.
I have a WRX Turbo Setup on my 1.8 L, and it has been doing fine for over a year now, until recently it "won't start" sometimes in the morning. It would try to turn over (cranking.. cranking) but no spark, but there is fuel since you can smell it after a few cranks. What's funny is that it would later on in the day start up... afternoon.. early evening. I'm very puzzled by that... it would run normal after that.
I've check all the fuses under the dash and under the hood.. everything looks fine. I've checked wiring of all my electronical components:
Apexi Ignition Timing Controller
Apexi S-AFC
Blitz Turbo Timer
If anyone has had any similar problems.. please.. please.. let me know...
Apexi S-AFC
Blitz Turbo Timer
you can check your ignition system for loose connections and bad plugs but it is most likely the crank and cam trigger sensors
this is a common problem on older 1.8 and so is the temp sensor going bad(mine is going bad)
what boost are you running?
zionsyouth86
Feb 23, 2005 10:25 PM
Wagon Joe
Dec 10, 2003 01:18 PM
EddyRS
Oct 18, 2003 01:29 PM
