93 Impreza L Turbo Won't Start! Help
Old Sep 17, 2004 | 01:19 PM
Kay95's Avatar
you can check your ignition system for loose connections and bad plugs but it is most likely the crank and cam trigger sensors
this is a common problem on older 1.8 and so is the temp sensor going bad(mine is going bad)
what boost are you running?
03_Impreza_Al
Nov 16, 2006 10:42 PM
zionsyouth86
Feb 23, 2005 10:25 PM
Wagon Joe
Dec 10, 2003 01:18 PM
EddyRS
Oct 18, 2003 01:29 PM
