Problem with parking (on hills)..need help!
Old Sep 10, 2004 | 06:47 PM
hYpE-R-29's Avatar
Ok heres the situaton..I live on a hill, and was going to the WRX downwards. So i did the typical things...I pointed the wheels to the curb, threw the car in first gear, shut off the clutch and let go of the clutch gently....I thought the car was suppose to stop, but it kept on going down hill....Is this normal for WRX's?..did i do anything wrong?...Am i suppose to put it in reverse instead of first gear?...Could I have done any damage(the car wasen't turn on when rolling)
**Note** I just got the WRX 2 days ago, its a 2002 with 17K miles..bone stock...
Old Sep 10, 2004 | 06:49 PM
ish's Avatar
ish
well if its facing downhill then you would want to put it in reverse. oh and putting the parking brake on helps as well. and wouldn't turning the wheels into the curb prevent the car from rolling downhill?
Old Sep 10, 2004 | 06:53 PM
brucelee's Avatar
Friendly Neighborhood Ogre
Car Info: GUNATICS.COM
get your E-brake re-adjusted.
Old Sep 10, 2004 | 07:02 PM
hYpE-R-29's Avatar
i did have e-brake up also brakes were done on monday by a subaru dealer...i just want to know if any damage is caused by me rolling on first gear??
Old Sep 10, 2004 | 07:03 PM
brucelee's Avatar
no. If it was only a few feet... its nothing to worry about.
Old Sep 10, 2004 | 07:55 PM
Littleboyblue's Avatar
I'm trying to understand this. You had it in gear, the parking brake was all the way up, and the tires were pointed toward the curb? You must be leaving something out because I could see one of these failing, but not all three. Maybe I misunderstood what you said.
Old Sep 10, 2004 | 07:56 PM
kravdra's Avatar
Car Info: '99 Impreza OBS
[QUOTE=wrx ish]well if its facing downhill then you would want to put it in reverse.QUOTE]
Stupid question, but why reverse? aren't reverse and 1st the same gear ratios?
Old Sep 10, 2004 | 08:24 PM
hYpE-R-29's Avatar
yup..i put it in 1st gear...shut car down, pointed wheels toward curp...let brake go...car started to move.....pulled ebrake...still kept going
Old Sep 10, 2004 | 09:35 PM
Keisatsu's Avatar
Car Info: Broken ass stock '02 WRX
my wrx has always rolled a little (few inches) after setting parking brake putting in gear etc... so have all 3 of my friends '02 wrxs, i always considered this normal :-\
Old Sep 11, 2004 | 12:33 AM
Crazy, there has to be something wrong. I could see one thing fail, but not all three. Have you called the dealer to inform them on the problem? That would be the first thing that I would do. Also, stop the car on a flat spot and put it into gear. Then go behind the car or have a friend push the car. See if it moves. Try it with the parking brake. If it does, then show the dealership. They would then have to fix it.
Old Sep 11, 2004 | 08:22 AM
hYpE-R-29's Avatar
Actually after that I parked it in my driveway with a slight incline...put it in neutral and pulled the e-brake....it stopped.....i must have done something wrong....!!
Old Sep 11, 2004 | 10:00 AM
bringndefinitio's Avatar
Car Info: 03 WRX + 08 335i + 07 Tahoe Lt3
wassup, don't see you in school anymore lol... But yeah do you have a jack I can borrow?? Going to change my tranny oil and my jack is broke! Let me know, and don't hestitate to hit me up for some of your installs =P
Old Sep 11, 2004 | 10:21 AM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
you didn't put it on 1st gear!. . . you thought you put it on first gear but you didn't. If you did, then there's something wrong with your car.
Here's what happened to my car when I didn't put it on 1st and didn't put the Ebrake all the way up....
https://www.i-club.com/forums/subaru-general-30/im-idiot-look-what-happened-my-car-70373/
Old Sep 11, 2004 | 10:36 AM
BoxerRumble's Avatar
Car Info: 2005 STi Silver
does this happen all the time or was it just htat one time?
Old Sep 11, 2004 | 03:51 PM
hYpE-R-29's Avatar
just once..i think i messed up somewhere
