Engine problem (non subaru) and shop recommendation.
Old Jul 8, 2009 | 02:37 PM
BoxerRumble's Avatar
Car Info: 2005 STi Silver
I just have a quick general engine related question, not for a Subaru but since you guys are very knowledgeable about cars in general, someone might be able to help.
The car is a 2000 Toyota Camry. The problem is when the car starts in cold weather, it will turn over, the revs will go up, then right away it will drop from like 1k down to 0 and the car shuts off. The car will start to shake and stutter then die. To remedy this, if I rev the car for a little while at like 2-3k and keep revving, once the engine warms the RPM will stay at idle and the car runs fine. This usually only happens in the morning when the car and weather is cold. Any ideas what the problem could be? Thanks!
Old Jul 8, 2009 | 03:20 PM
im sure paul can do it
it sounds like an idle valve they go out qutie a bit on those
or a cold start valve
but i have no clue
Old Jul 8, 2009 | 04:30 PM
Unit 91's Avatar
i-Club Sympathizer
Probably a bad IAC, but that isn't a definitive answer. Just a quick gut feeling.
Old Jul 8, 2009 | 04:33 PM
+1 to that
Old Jul 8, 2009 | 04:34 PM
Unit 91's Avatar
i-Club Sympathizer
You can take it off and clean it. See if that helps the problem. Would also confirm the issue.
FRAWSTI
Dec 24, 2013 10:41 AM
dub81
Nov 21, 2007 11:20 AM
estrada42
Oct 24, 2004 03:38 PM
IgotWRXed
Mar 13, 2003 06:54 PM
deepbeep
Feb 13, 2003 02:09 PM
