Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
will engine CR affect turbo efficiency?
Old Dec 19, 2002 | 07:22 PM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
I think the 9:1 compression is to help throttle response and low end torque. Cam selection and turbo size will help spool up more than compression IMO. I believe that both an 8:1 engine and a 9:1 engine without changing cams should flow close to the same amount of air (it depends on what the changed factor is: bigger dished pistons or larger combustion chamber to reduce compression- a larger combustion chamber won't get more air through the engine). The extra squeeze only increases the volatility of the air fuel mixture in the cylinders. This results in a stronger combustion. Now the extra energy added to the exhausting... uh... exhaust could be transfered to the turbo and help it spool quicker. However, it sounds kinda far fetched. A 9:1 engine revs quicker than an 8:1 engine which could make the turbo appear to spool slower because it hasn't had time to spin faster....
it's all speculation from my computer....
but I don't think it'll spool faster on a 9:1
JUNNEL20
Oct 23, 2004 09:50 AM
grknss
Oct 16, 2003 08:12 AM
suprawrx
May 23, 2003 08:58 PM
