advantages and disadvantages with oil or water cooleed
just wondering what the advantages and disadvantages were of running a oil only cooled turbo. I have a 05 sti if that makes a difference. Same with ol and water. anyone know?
Car Info: 05 STi
Oil is prone to coking which can be detrimental to a turbo. Over time they require more maintenance but given the performance application with which you'll be using it, that should be expected. If you take the proper measures such as a turbo timer, doing the scheduled maintenance and perhaps installing an oil cooler you'll make the differences negligable. Don't let the cooling of a turbo determine your choice, there are much greater considerations to worry about (i.e. spool, boost potential, manifold options, supporting mods, etc...)
Car Info: 05 STi
Originally Posted by soobie05
this one is also set up for a external wastegate...is that made for higher boosting cars?
timeless
05-01-2006 09:38 AM
projectwrx
13
01-27-2006 01:53 PM
method1
04-05-2005 09:56 PM
rustokman
09-08-2004 12:33 PM
