30k/60k/90k/105k and 120k services! All OEM parts and non Dealership Pricing!
Due to many calls/PM's about services, figured I'll post it up for you guys to see what's everything we do for your Suby.
30K,90k Mile Service : Price $350 OTD ($380 for 4eat) Automatic add +50
* Mobil 1 Synthetic 5W-30 Oil W/ OEM Oil filter and Crush Washer
* Tranny Fluid Flush:
* Rear Diff Fluid Change:
* Coolant Flush
* Brake Fluid Flush: Valvoline Synthetic or ADD$50 for Motul RBF600
* OEM Air Filter
* OEM Fuel Filter (not done on cars with intank filter at this mileage)
* Check and Top Off All Fluid
* Tire Rotation , Check Pressure & Retorque Wheels
* Inspect Brakes, Belts, Oil leaks and ETC....
60K,120k Mile Service : Price $450 OTD ($480 for 4eat) Automatic add +50
* Same as 30/90k along with Denso Iridium Spark Plugs for 2.5L. NGK Platinums for 2.0L.
These Services will usually take about 3-4 hours
Also... Every 105K miles, you should change out your Timing belt and Water Pump.
We ONLY Use OEM Subaru Parts
Price: $1450
* OEM Timing Belt
* OEM Timing Belt Tensioner
* OEM Water Pump + gasket
* OEM Thermostat + gasket
* OEM Idler Pulleys (4)
* OEM Crank Seal
* Coolant Flush
GREDDY Timing Belt upgrade also available for extra charge
Timing Belt Service will be a Full-Day 8 Hour Job.
Please give us a Call to schedule an Appointment
Thanks,
Ryan
* Coolant Flush
* OEM Air Filter
Price: $1450
* OEM Timing Belt
* OEM Crank Seal
* Coolant Flush
Thanks,
Ryan
Car Info: 04' WRX wagon, 91' SE-R
60K service on 2004 WRX wagon quote pls? Can I drop off the car at night? PM is fine
Speed Element
Tuning, Services, and Installs
17
02-08-2012 09:35 AM
GST Motorsports
12-15-2011 02:11 PM
Speed Element
12-02-2009 05:04 PM
njchen24
10-24-2005 03:39 AM
