30k/60k/90k/105k and 120k services! All OEM parts and non Dealership Pricing!
[b]Due to many calls/PM's about services, figured I'll post it up for you guys to see what's everything we do for your Suby.
[color=blue][size=3]30K,90k Mile Service : Price $350 OTD ($380 for 4eat) Automatic add +50[/size] * Mobil 1 Synthetic 5W-30 Oil W/ OEM Oil filter and Crush Washer * Tranny Fluid Flush: * Rear Diff Fluid Change: * Coolant Flush * Brake Fluid Flush: Valvoline Synthetic or ADD$50 for Motul RBF600 * OEM Air Filter * OEM Fuel Filter (not done on cars with intank filter at this mileage) * Check and Top Off All Fluid * Tire Rotation , Check Pressure & Retorque Wheels * Inspect Brakes, Belts, Oil leaks and ETC....[/color] [color=red][size=3]60K,120k Mile Service : Price $450 OTD ($480 for 4eat) Automatic add +50[/size] * Same as 30/90k along with Denso Iridium Spark Plugs for 2.5L. NGK Platinums for 2.0L. [/color] These Services will usually take about 3-4 hours [color=green][size=3]Also... Every 105K miles, you should change out your Timing belt and Water Pump. We ONLY Use OEM Subaru Parts Price: $1450[/size] * OEM Timing Belt * OEM Timing Belt Tensioner * OEM Water Pump + gasket * OEM Thermostat + gasket * OEM Idler Pulleys (4) * OEM Crank Seal * Coolant Flush GREDDY Timing Belt upgrade also available for extra charge[/color] Timing Belt Service will be a Full-Day 8 Hour Job. Please give us a Call to schedule an Appointment[/b] Thanks, Ryan |
:bump:
[QUOTE=Speed Element;2770811]:bump:[/QUOTE]
: banana : |
How much for just the inspection, coolant flush, brake service + installing my ss lines, and fuel filter (if applicable on my 07 wrx)? you can pm a quote.
i might need this 30k service soon. :-)
[QUOTE=D. Fantom;2818222]How much for just the inspection, coolant flush, brake service + installing my ss lines, and fuel filter (if applicable on my 07 wrx)? you can pm a quote.[/QUOTE]
Pm'ed :) |
toooo the top!
105k service with oil pump quote? PM is fine
2002 wrx sedan with a 5spd for car info, got 86k right now but oil pump is a bit leaky |
[QUOTE=Dans Rex;2891055]105k service with oil pump quote? PM is fine
2002 wrx sedan with a 5spd for car info, got 86k right now but oil pump is a bit leaky[/QUOTE] pm'd ya |
60K service on 2004 WRX wagon quote pls? Can I drop off the car at night? PM is fine
Interested in the 60K service for 2002 WRX wagon. I also need axle seal replaced on the transmission (passenger side) as mine is leaking. Quote for both please. Thanks.
PM sent/replied.
