Tomei vs Killer B EL headers
Old 09-12-2012, 03:29 PM
brewsky79's Avatar
Car Info: his wife crazy
I'm in the market for a set of EL headers and I have narrowed my choices to the Tomei Expreme EL header and the Killer B Holy Header.
Anyone have any experiences/opinions about the above mentioned?
Thanks in advance.
brewsky79 is offline
Old 09-12-2012, 03:34 PM
CcaniaSTI's Avatar
Car Info: Flared laguna seca GD
Both are great headers that willl give you good gains. Killer b are practically indistructable havent heard of tomei cracking either, killer b has that lifetime warrenty. If your on a budget id go with tomei id you got the cash $$$ get some killer b headers. Or even full-race ones
CcaniaSTI is offline
Old 09-12-2012, 03:37 PM
flat489's Avatar
Car Info: '11 STI
I think that there is a group buy going on through Boston Motorsports for the KillerB headers, they also are very active on Nasioc so I am guessing customer service is probably good too
flat489 is offline
Old 09-12-2012, 03:40 PM
Lil' Slugger
k-dogg39's Avatar
Car Info: 05 WRB STi Wagon/00 BRP GC Sedan
GB just ended at the end of Aug. Like the others said, if you have the money, go with Killer B.
k-dogg39 is offline
Old 09-12-2012, 03:46 PM
WRX Coastie's Avatar
Car Info: COBB ots Stg 2, 06 STi
I bought Tomei Expreme UEL Headers w up-pipe and they look fantastic, welds were perfectly beaded almost too good looking to install. Anyways I have had mine on the Sti for 8K miles now and they still look great no leaks or cracks. I know they are not EL but same company and similar component. No fitiment issues whatsoever.
just my 2 cents, overall very happy I bought them.
WRX Coastie is offline
Old 09-12-2012, 05:54 PM
Technical Know-It-All
Brfatal's Avatar
Car Info: '02 WRX + '15 WRX
Tomei will break. It's not made of materials that will withstand higher EGTs. The Killer B one won't.
Brfatal is offline
Old 09-12-2012, 07:50 PM
brewsky79's Avatar
I appreciate everyone's input on this topic. It looks like I may go with Killer B. I have heard (not just from this thread) that Tomei has had cracking issues before. But I suspect that may be on a case by case issue. Tomei is a great company with awesome products and I will leave it at that.
I will continue looking into the Killer B setup as they are made of 321 SS and thus have a higher content of titanium which will resist heat a bit more than 304 SS.
Thanks again everyone!
Old 05-27-2013, 10:42 PM
Slide's Avatar
Car Info: 2013 STI Hatch
Thread back from the dead. Which did you go with and any reviews? Putting together a parts list for the next stage on my car...
Slide is offline
Old 06-03-2013, 06:35 PM
RobbyRing's Avatar
Car Info: 2004 Subaru WRX Java Black Pearl
Bumpitty bump bump. Looking at a set if tomei el with up $425
RobbyRing is offline
Old 06-04-2013, 01:30 PM
RobbyRing's Avatar
Bump bump
Old 06-04-2013, 03:53 PM
Concillian's Avatar
Car Info: 02 WRX sedan
Tomei ELs are basically like any of the other "3 bolt uppipe" ELs that I will call "3 bolt" headers. EQ tuning thinks well enough of the product that they have an EQ branded version of the same thing.
For the street it's probably adequate. Going to something like the FR or KillerB is for cars that will see enough high performance driving that the higher end materials are worth the cost.
The 3 bolt ELs may last 3-5 years of street driving and and they're inexpensive enough to replace when / if they crack. The KillerB or FR headers will last forever but the initial cost is more than 2 or 3 of the "3 bolt" headers.
IMO it's not worth pursuing the expensive headers for performance gains, as that's pretty minimal. It basically comes down to if you're tracking the car and seeing a high % of the time at high EGTs, then the 3 bolts will crack often enough that it's probably worthwhile to shell out for the expensive brands with better materials. If you're street driving, then go for the "3 bolt" headers.
Concillian is offline
Old 06-04-2013, 05:48 PM
RobbyRing's Avatar
Thanks!
jung187
02-08-2011 06:40 PM
STi33W
05-01-2010 12:33 AM
dlogfx
10-22-2008 10:13 PM
Max Xevious
03-22-2006 12:12 PM
Wrxplaya11
01-07-2004 05:33 PM
Quick Reply: Tomei vs Killer B EL headers
