Perrin big maf
Old 04-03-2015, 07:44 PM
Evilo6rex's Avatar
Car Info: 2006 subaru wrx tr
Perrin big maf
Was looking on getting rid of my cold air and getting the Perrin short ram and big maf. Newbie question what will the larger maf do will it allow more or air just curious thanks
Evilo6rex is offline
Old 04-05-2015, 11:34 AM
northernsubie4's Avatar
I have a ams MAF and I upgraded it because of my set up. I have a rotated turbo set up running 512 hp. The reason to upgrade the maf is because when you change your turbo the air that comes in the larger turbo the old small MAF won't read the large amount of air flowing through. So if your car is stock and your on the stock turbo it's pointless to upgrade the maf. You can still do a cold air but you don't need to upgrade the maf. Once you start hitting 400hp you will want to upgrade it. If you don't need to upgrade it don't. Saves you money to spend on other stuff. You should upgrade your fuelling before your maf
northernsubie4 is offline
Shagon Wagon
02-05-2014 01:56 PM
dahgoose
05-03-2013 09:44 PM
verc
05-14-2009 08:10 PM
dan avoN7
12-19-2006 09:46 AM
pj21086
01-11-2006 11:56 PM
Quick Reply: Perrin big maf
