How to convert a slip ring motor into an alternator?
Old 08-10-2012, 10:52 PM
Jani Raxter's Avatar
Car Info: Jani Raxter
If the motor has two rotary joint, it is a synchronous motor. It can be operated as a synchronous generator by applying the proper DC excitation fiber optical rotary joints to the slip rings, connecting a 3-phase load to the stator and turning the shaft. The motor's nameplate should provide rotor and stator voltage and current ratings.
If the motor has three fiber optical rotary joint, it is an induction generator. If DC is applied between any two slip rings, it can probably be operated as a synchronous generator, but it probably will not perform as well as a machine that is designed as a synchronous machine. The motor's nameplate should provide the stator voltage, current and frequency ratings. You will probably need to determine the rotor voltage and current experimentally.
Jani Raxter is offline
Old 08-11-2012, 12:25 AM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
Wut?
1JavaBlk_in_Sac is offline
iLoqin
11-30-2009 01:00 PM
not12listen
10-02-2008 06:55 PM
Paradox
13
01-03-2008 10:57 PM
Imprezer
04-26-2004 05:54 PM
WorldONE
04-14-2004 09:27 AM
Quick Reply: How to convert a slip ring motor into an alternator?
