Will a 17x8 with a 53 mm offset fit a 05 RS Wagon?
Old Apr 10, 2006 | 03:16 AM
beachcar's Avatar
Car Info: 2.5 rs wagon 2005
Question Will a 17x8 with a 53 mm offset fit a 05 RS Wagon?
I was thinking of purchasing a 17x8 with a 53 mm offset rim and was wondering if there are any clearance issues with an 05 rs Wagon? Your guys help is greatly appreciated! Also what tire width would be good? Ride height is stock... Thanks again!
Attached Thumbnails Will a 17x8 with a 53 mm offset fit a 05 RS Wagon?-aly68742u.jpg
Old Apr 12, 2006 | 10:11 PM
EsoterikWRX's Avatar
Car Info: PSM 2K2 WRX Wagon
Those look to be STI takeoffs. If they are, then you may have problems if you have already purchased them. If the wheels are 17x8, then they are from an newer STI with the 5x114.3mm bolt pattern, & your car has a 5x100mm bolt pattern. If the wheels have the correct bolt pattern for your car, then yes, they will fit, but tire selsction will be critical.
Old Apr 13, 2006 | 03:26 PM
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
04 STi is still 5x100
Old Apr 14, 2006 | 06:02 PM
HomerJay's Avatar
Car Info: MY00RS25
What he said.
But '04 STI wheels are 17x7.5.
Old Apr 15, 2006 | 12:48 PM
mattsn0w's Avatar
pretty much any Subaru Impreza wheel will fit. With the wagons a 48 offset works well, I think a 50-52 would be better, can't remember.
As for tires, depends on where you drive. for summer and rain, the Falken GFB FK-451 tires are great! a 215/45/17 or 225/45/17 will fit fine on the wagon. If you go to the snow and don't do a whole lot of spirited driving, the Pirelli PZero Nero M+S is a great tire, high tread rating, great all around grip, even better in the wet. Just don't get them too hot(auto-x/track type beating) otherwise the stickiness goes to ****. Then you have to wait a thousand miles or so for that burnt rubber to wear off. its kind of odd sounding, but this happened on the set I had as well as a fried with an STi.
Old Apr 24, 2006 | 11:17 PM
DUH - if they are 17x8 STI takeoffs then they must be from an 05+ STI, & those won't work on a WRX.
b00staholic
Nov 28, 2012 09:43 PM
beat
Jun 2, 2010 04:31 AM
LukeSTi
Aug 7, 2005 05:55 PM
subzero_Gt
May 9, 2004 10:30 AM
